[postgis-tickets] [PostGIS] #3916: Make install no longer works under mingw64
PostGIS trac at osgeo.org
Thu Oct 26 10:04:35 PDT 2017
  Reporter:  robe       |      Owner:  strk
      Type:  defect     |     Status:  new
  Priority:  blocker    |  Milestone:  PostGIS 2.2.7
 Component:  buildbots  |    Version:  2.4.x
Resolution:             |   Keywords:
Comment (by robe):
 In [changeset:"16067" 16067]:
 #!CommitTicketReference repository="" revision="16067"
 Add a AC_PROG_INSTALL step to configure.ac to fix.
 References #3916
 References #3912
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3916#comment:11>
