[postgis-tickets] r16071 - Ignore new generated files
Paul Ramsey
pramsey at cleverelephant.ca
Fri Oct 27 09:05:19 PDT 2017
Author: pramsey
Date: 2017-10-27 09:05:19 -0700 (Fri, 27 Oct 2017)
New Revision: 16071
trunk/.gitignore
Modified: trunk/.gitignore
--- trunk/.gitignore 2017-10-27 07:50:56 UTC (rev 16070)
+++ trunk/.gitignore 2017-10-27 16:05:19 UTC (rev 16071)
@@ -14,7 +14,10 @@
postgis_svn_revision.h
aclocal.m4
autom4te.cache/
+build-aux/
config.log
+config.guess
+config.sub
config.status
configure
@@ -67,12 +70,15 @@
extensions/postgis_topology/sql/
extensions/postgis_topology/sql_bits/*.sql
GNUmakefile
+install-sh
java/jdbc/Makefile
java/jdbc/lib/
java/jdbc/pom.xml
java/jdbc/target/
liblwgeom/cunit/cu_tester
liblwgeom/cunit/Makefile
+liblwgeom/geobuf.pb-c.c
+liblwgeom/geobuf.pb-c.h
liblwgeom/liblwgeom.a
liblwgeom/liblwgeom.h
liblwgeom/Makefile
@@ -84,7 +90,6 @@
loader/shp2pgsql
loader/shp2pgsql-gui
ltmain.sh
-build-aux/
macros/libtool.m4
macros/lt~obsolete.m4
macros/ltoptions.m4
