[postgis-tickets] [PostGIS] #3912: glibtoolize doesn't install install-sh
trac at osgeo.org
Sat Oct 28 10:04:34 PDT 2017
Reporter: pramsey | Owner: strk
Type: defect | Status: reopened
Priority: blocker | Milestone: PostGIS 2.2.7
Component: postgis | Version: 2.4.x
Resolution: | Keywords:
Comment (by robe):
In [changeset:"16073" 16073]:
#!CommitTicketReference repository="" revision="16073"
Hard-code build-aux/install-sh in all install scripts
instead of relying on @INSTALL@ to pick an install executable
on systems where @INSTALL@ resolves, ends up picking the system preferred
install
which at least on mingw64 won't directories if they don't exist
in addition on mingw64, it doesn't
even fill in @INSTALL@ with install unless AC_PROG_INSALL is included
References #3916 for PostGIS 2.5 (trunk)
References #3912 for PostGIS 2.5 (trunk)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3912#comment:15>
