[postgis-tickets] [PostGIS] #3916: Make install no longer works under mingw64
PostGIS trac at osgeo.org
Sat Oct 28 10:04:35 PDT 2017
  Reporter:  robe       |      Owner:  strk
      Type:  defect     |     Status:  new
  Priority:  blocker    |  Milestone:  PostGIS 2.2.7
 Component:  buildbots  |    Version:  2.4.x
Resolution:             |   Keywords:
Comment (by robe):
 In [changeset:"16073" 16073]:
 #!CommitTicketReference repository="" revision="16073"
 Hard-code build-aux/install-sh in all install scripts
 instead of relying on @INSTALL@ to pick an install executable
 on systems where @INSTALL@ resolves, ends up picking the system preferred
 install
 which at least on mingw64 won't directories if they don't exist
 in addition on mingw64, it doesn't
 even fill in @INSTALL@ with install unless AC_PROG_INSALL is included
 References #3916 for PostGIS 2.5 (trunk)
 References #3912 for PostGIS 2.5 (trunk)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3916#comment:16>
