[postgis-tickets] [PostGIS] #3921: ALTER EXTENSION upgrade failing at ST_CurveToLine
trac at osgeo.org
Sat Oct 28 10:44:02 PDT 2017
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.5.0
Component: build/upgrade/install | Version: trunk
Keywords: |
After I resolved the make install issue at #3916
this issue was uncovered on winnie
Preparing db 'postgis_reg' using: CREATE EXTENSION postgis
Upgrading PostGIS in 'postgis_reg' using: ALTER EXTENSION postgis UPDATE
TO '2.5.0devnext'
Died at run_test.pl line 1423.
failed (Error encountered altering EXTENSION POSTGIS:
/projects/postgis/tmp/2.5.0dev_pg10_geos3.7.0dev_gdal2.2.2w64/regress_log)
sh: createlang: command not found
CREATE EXTENSION
CREATE EXTENSION
ERROR: cannot remove parameter defaults from existing function
HINT: Use DROP FUNCTION st_curvetoline(geometry,double
precision,integer,integer) first.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3921>
