[postgis-tickets] [PostGIS] #3921: ALTER EXTENSION upgrade failing at ST_CurveToLine
PostGIS trac at osgeo.org
Sat Oct 28 11:14:02 PDT 2017
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  new
  Priority:  blocker    |  Milestone:  PostGIS 2.5.0
 Component:  buildbots  |    Version:  trunk
Resolution:             |   Keywords:
Comment (by robe):
 Ahah I see r16045 is the culprit.  I think it's an accident that winnie
 was picking up on this though (though it is probably something that will
 be an issue upgrading from 2.4.* to 2.5, because you can't change default
 args without dropping old first)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3921#comment:2>
