[postgis-tickets] [PostGIS] #3921: ALTER EXTENSION upgrade failing at ST_CurveToLine
trac at osgeo.org
Sat Oct 28 11:55:01 PDT 2017
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.5.0
Component: buildbots | Version: trunk
Resolution: | Keywords:
Comment (by robe):
In [changeset:"16075" 16075]:
#!CommitTicketReference repository="" revision="16075"
revise winnie's regess and package script copying to edb install to copy
over non-versioned .sql file as well.
Actually unversioned .sql aren't used at all, it was the next.sql scripts
that weren't being overridden
references #3921
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3921#comment:6>
