[postgis-tickets] [PostGIS] #3916: Make install no longer works under mingw64
trac at osgeo.org
Sun Oct 29 10:23:08 PDT 2017
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.2.7
Component: buildbots | Version: 2.4.x
Resolution: | Keywords:
Comment (by strk):
Our configure should already obey --prefix, or even the more
restrictive --includedir, please file a separate ticket if it doesn't
Not installing it would require statically linking shp2pgsql and
pgsql2shp, which should probably be a builder's choice to make.
We know Debian packagers are much happier with that library being
linked dynamically, to be able to provide quick fixes to security
issues.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3916#comment:19>
