[postgis-tickets] [PostGIS] #3913: Include minor upgrade in extension-from-unpackaged script
PostGIS trac at osgeo.org
Sun Oct 29 10:47:05 PDT 2017
  Reporter:  strk     |      Owner:  robe
      Type:  defect   |     Status:  reopened
  Priority:  medium   |  Milestone:  PostGIS 2.5.0
 Component:  postgis  |    Version:  2.4.x
Resolution:           |   Keywords:
Comment (by strk):
 I've been pointed out to the fact that "object_not_in_prerequisite_state"
 would also be thrown if the object being added to an extension is already
 registered as being part of _another_ extension, and that there are
 possibly other cases in which it can be thrown which do not even relate to
 extensions...
 So the code should be further modified to "manually" implement the "IF NOT
 EXISTS" part
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3913#comment:9>
