[postgis-tickets] [PostGIS] #3912: glibtoolize doesn't install install-sh
PostGIS trac at osgeo.org
Mon Oct 30 13:34:37 PDT 2017
  Reporter:  pramsey  |      Owner:  strk
      Type:  defect   |     Status:  reopened
  Priority:  blocker  |  Milestone:  PostGIS 2.2.7
 Component:  postgis  |    Version:  2.4.x
Resolution:           |   Keywords:
Comment (by robe):
 In [changeset:"16083" 16083]:
 #!CommitTicketReference repository="" revision="16083"
 change back to using @INSTALL@ and put in AC_PROG_INSTALL
 so install doesn't go to ../ for insall on mingw
 References #3916
 References #3912
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3912#comment:17>
