[postgis-tickets] r16085 - Move protobuf tests into protobuf guarded file (closes #3922)
Paul Ramsey pramsey at cleverelephant.ca
Mon Oct 30 17:33:40 PDT 2017
Author: pramsey
Date: 2017-10-30 17:33:40 -0700 (Mon, 30 Oct 2017)
New Revision: 16085
   trunk/regress/mvt.sql
   trunk/regress/mvt_expected
   trunk/regress/tickets.sql
   trunk/regress/tickets_expected
Modified: trunk/regress/mvt.sql
--- trunk/regress/mvt.sql	2017-10-30 20:58:59 UTC (rev 16084)
+++ trunk/regress/mvt.sql	2017-10-31 00:33:40 UTC (rev 16085)
@@ -160,3 +160,13 @@
 SELECT encode(ST_AsMVT(1, 'test', 4096, 'geom'), 'base64');
 SELECT 'TU3', encode(ST_AsMVT(q, 'test', 4096, 'geom'), 'base64')
     FROM (SELECT NULL::integer AS c1, NULL AS geom) AS q;
+-- Ticket #3922
+SELECT '#3922', length(bytea(ST_AsMVTGeom(
+		st_geomfromtwkb('\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
 44e3e54355c064a45880115289d01103904453e810127290b5103a70152174841680b10254814402a4e305e82017232581792010522512e2516370023380b9801125434584c2a3e5202042f4e390f2f0e050205001f0801380d00430515421744fd01311b16614c038001241a482c3e44061e0a3881012605244d0e2d5d291a192c5710759d01284b20150f752308530a7f198101113d145d1f13534727290a291f490f4b0215246b196929752d2f2581012675371d432f090c4d2c0d080b141f0a0034051401110735152921055940010a023c0c0c35030519270825382f104512753e014001ae013b041708356ced012a0f7c2d041d0415631507e501012f0a491327411d1b310811072947493d0843125f4b7b16'),
+		'SRID=3347;POLYGON((3658201 658873,3658201 5958872.97428571,8958201.49428571 5958872.97428571,8958201.49428571 658873,3658201 658873))'::geometry,
+		4096,
+		0,
+		true
Modified: trunk/regress/mvt_expected
--- trunk/regress/mvt_expected	2017-10-30 20:58:59 UTC (rev 16084)
+++ trunk/regress/mvt_expected	2017-10-31 00:33:40 UTC (rev 16085)
@@ -41,3 +41,4 @@
 TU2
 ERROR:  pgis_asmvt_transfn: parameter row cannot be other than a rowtype
 TU3|
+#3922|323
Modified: trunk/regress/tickets.sql
--- trunk/regress/tickets.sql	2017-10-30 20:58:59 UTC (rev 16084)
+++ trunk/regress/tickets.sql	2017-10-31 00:33:40 UTC (rev 16085)
@@ -1055,13 +1055,7 @@
 ) a;
 DROP TABLE IF EXISTS rec;
-SELECT '#3922', length(bytea(ST_AsMVTGeom(
-st_geomfromtwkb('\x06000104a501d0a7db06dad0940120ee030660229604109c010ed6011246143e76201a22b401a601f001b801580ef40122d803ca01de0cf00e80049204ac02b602be0138ca08bc02d605d201d2013cb804a401be013c9c03cd028608c106f001c1018601c7011e970125f10207439b02850a76ff0415030d0725431973132f227768671a5f133f17290865e405ba0154ab030415348502cc038d120c37d326c706850896109f01e201350f6f0a1903930165830121412d052928651d2b0d0f1107170b490c33120f010f0813034f47f50259190181031b3713ed04d901bd01439b02639507c10201021062054c1d3c101e6a0c2000684e6a7c1a681f443d160f044f0f490f03020b08051c01080c0e18013a012801380e08005808522d3a4c1c062a0f0e192a190a3b22194803261c1376122ac201d8011a101c065a17a8011c303206460c164a18a4015c56620801162d1404a402c601262a143002421222290f7b581d0719011d0311002908250a25021d030f0111030f05a3014315050d05110383011b9d011f3309a70347170325058b03417515130361190b4e19b40105fe208810041314041018270705c0039d0416251a1213241b0ffd02f5029408d001990218110607100c070a0b0819031c263432302454322a1e262a101e2a521426101c0c1010121012
 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
-'SRID=3347;POLYGON((3658201 658873,3658201 5958872.97428571,8958201.49428571 5958872.97428571,8958201.49428571 658873,3658201 658873))'::geometry,
-4096,
-0,
-true
 -- Clean up
 DELETE FROM spatial_ref_sys;
Modified: trunk/regress/tickets_expected
--- trunk/regress/tickets_expected	2017-10-30 20:58:59 UTC (rev 16084)
+++ trunk/regress/tickets_expected	2017-10-31 00:33:40 UTC (rev 16085)
@@ -314,4 +314,3 @@
 #1014c|3|POINT(2 3)
 #1014d|SRID=1;POINT(0 1)
 #1014d|SRID=2;POINT(0 1)
-#3922|323
