[postgis-tickets] [PostGIS] #3914: ERROR: XX000: SQL/MM Spatial exception - geometry crosses edge 3051
PostGIS trac at osgeo.org
Tue Oct 31 05:02:54 PDT 2017
  Reporter:  laopsahl  |      Owner:  pramsey
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:
 Component:  postgis   |    Version:  trunk
Resolution:            |   Keywords:
Comment (by laopsahl):
 Why is this code working ok ?
 select DropTopology('test_snapto');
 select CreateTopology('test_snapto');
 select TopoGeo_addLinestring('test_snapto','LINESTRING(609285.46
 6549990.58,609277.63 6549983.87)',0);
 SELECT ST_Length(geom) from test_snapto.edge_data;
 select TopoGeo_addLinestring('test_snapto','LINESTRING(609281.0371
 6549986.79,609292 6549984)',2);
 And not this, where i add a new linstrings and then removes it, before
 adding the last line string ?
 select TopoGeo_addLinestring('test_snapto','LINESTRING(609277.63
 6549983.87,609281.0371 6549986.79)',0);
 select ST_RemEdgeModFace('test_snapto', 2);
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3914#comment:4>
