[postgis-tickets] [PostGIS] #3968: postgis geocode bug - invalid input syntax for type numeric
trac at osgeo.org
Tue Jan 2 06:11:33 PST 2018
Reporter: hammeryosi | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.4.3
Component: tiger geocoder | Version: 2.4.x
Keywords: |
I am using postgis with the tiger extension to geocode addresses in our
database at Dataline. I have successfully used it for tens of millions of
addresses before running into this issue with a specific address in North
Carolina. The geocoder function fails when I specify max_results=1.
Here’s what happens without specifying it:
select geocode(normalize_address('6922 SURREY RD, FAYETTEVILLE, NC
28306'))
'("(6709,,Surrey,Rd,,,Fayetteville,NC,28306,t,,)",0101000020AD10000027ACEC8778C053C09480511ED27F4140,5)'
'("(198,,Sarah,Ln,,,Rockfish,NC,28306,t,,)",0101000020AD1000007EBC9E12A8C353C07DC16057347D4140,71)'
And with max_results=1
28306'), 1)
ERROR: invalid input syntax for type numeric: " "
CONTEXT: PL/pgSQL function geocode_address(norm_addy,integer,geometry)
line 204 at assignment
PL/pgSQL function geocode(norm_addy,integer,geometry) line 14 at FOR over
SELECT rows
SQL state: 22P02
This does not happen for other addresses, e.g.,
select geocode(normalize_address('6922 SIMS SCHOOL RD, SIMS, NC 27880'),
1)
'("(6922,,""Sims
School"",Rd,,,Sims,NC,27880,t,,)",0101000020AD100000D0EB95D6808353C0364C7D2CFEDF4140,0)'
My system info:
'PostgreSQL 10.1, compiled by Visual C++ build 1800, 64-bit'
'POSTGIS="2.4.1 r16012" PGSQL="100" GEOS="3.6.2-CAPI-1.10.2 4d2925d"
PROJ="Rel. 4.9.3, 15 August 2016" GDAL="GDAL 2.2.2, released 2017/09/15"
LIBXML="2.7.8" LIBJSON="0.12" LIBPROTOBUF="1.2.1" RASTER'
Any help would be appreciated.
Thanks!
Yosi Hammer,
Data scientist at Dataline (http:\\www.datalinedata.com)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3968>
