[postgis-tickets] [PostGIS] #3968: postgis geocode bug - invalid input syntax for type numeric
trac at osgeo.org
Wed Jan 3 15:58:45 PST 2018
Reporter: hammeryosi | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.4.3
Component: tiger geocoder | Version: 2.4.x
Resolution: | Keywords:
Comment (by robe):
Hammer,
I loaded NC tiger 2017 data and tested, and not seeing an issue.
SELECT geocode(normalize_address('6922 SURREY RD, FAYETTEVILLE, NC
28306'), 1);
outputs:
geocode
("(6922,,Surrey,Rd,,,Fayetteville,NC,28306,t,,)",0101000020AD100000B4AED5924DC1
53C0DFB3212DF17E4140,0)
(1 row)
28306'));
outputs
geocode
("(6709,,Surrey,Rd,,,Fayetteville,NC,28306,t,,)",0101000020AD10000027ACEC8778C0
53C09480511ED27F4140,5)
("(198,,Sarah,Ln,,,Rockfish,NC,28306,t,,)",0101000020AD1000007EBC9E12A8C353C07D
C16057347D4140,71)
(2 rows)
I'm running:
PostgreSQL 10.1, compiled by Visual C++ build 1800, 64-bit
POSTGIS="2.4.2 r16113" PGSQL="100" GEOS="3.6.2-CAPI-1.10.2 4d2925d"
PROJ="Rel. 4.9.3, 15 August 2016" GDAL="GDAL 2.2.2, released 2017/09/15"
LIBXML="2.7.8" LIBJSON="0.12" LIBPROTOBUF="1.2.1" RASTER
Very similar to yours, so I'm guessing you might be running an unpatched
tiger geocoder.
To check which version you are running, check what this outputs:
SELECT name, installed_version
FROM pg_available_extensions WHERE name = 'postgis_tiger_geocoder';
name | installed_version
postgis_tiger_geocoder | 2.4.1
(1 row)
I thought maybe it was something I fixed in 2.4.2, but as you can see I
neglected to even upgrade my tiger to 2.4.2, so in theory I should be
running the same version as you.
If you see something less than 2.4.1, then run this:
ALTER EXTENSION postgis_tiger_geocoder UPDATE;
and that should bring you up to date. Hopefully will fix your issue.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3968#comment:2>
