[postgis-tickets] [PostGIS] #3957: ST_StartPoint - not works correctly
trac at osgeo.org
Mon Jan 8 06:38:57 PST 2018
Reporter: sanyasi | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.4.3
Component: postgis | Version: 2.4.x
Resolution: invalid | Keywords:
Changes (by pramsey):
* status: new => closed
* resolution: => invalid
Comment:
Without some attached data that shows the problem, this won't get touched.
The two queries run on different tables with different data, and the
results are... different. The fact that the human-readable versions appear
the same wouldn't surprise you if they were rounded to the nearest 0.1.
Would it surprise you to know that the binary representations differ only
in the two least-significant bits? The human readable forms just happen to
be rounded off before you can see those differences.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3957#comment:4>
