[postgis-tickets] [PostGIS] #3956: Upgrade does not upgrade geog_brin_inclusion_add_value function to use the updated module
trac at osgeo.org
Mon Jan 8 15:21:14 PST 2018
updated module
Reporter: keiko713 | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.4.3
Component: postgis | Version: 2.4.x
Resolution: | Keywords:
Comment (by robe):
keiko713,
Which version of PostgreSQL/PostGIS were you coming from? Please provide
output of
SELECT postgis_full_version() || ' ' || version();
on both your old and new cluster.
I'm looking at the latest upgrade script, and for PostgreSQL 9.5 and
above, the geog_brin_inclusion_add_value function is always updated as is
the case with all functions.
So the only reason why I can think this would have failed for you is 2
1) You are using scripts that were compiled against PostgreSQL 9.4 or
below to upgrade your database. The IF def is there to prevent these
functions and types from being installed. So if you are using these
upgrade scripts, yah these functions won't be in there.
strk - I forget, did we put in a check in 2.4 to prevent someone from
accidentally using scripts compiled against a lower version of PostgreSQL
on a higher version of PostgreSQL. If we did that would have caught this
case.
2) You are using a PostGIS micro before 2.3.3. I think then though, you
would have had issues as the upgrade script would include trying to
upgrade types you didn't have and you would have had to manually install
these to correct the situation as your upgrade would have failed.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3956#comment:5>
