[postgis-tickets] r16232 - Simplify syntax for brin opclasses so upgrade script recognizes it
Sandro Santilli
strk at kbt.io
Tue Jan 9 07:04:21 PST 2018
Author: strk
Date: 2018-01-09 07:04:21 -0800 (Tue, 09 Jan 2018)
New Revision: 16232
trunk/postgis/geography_brin.sql.in
trunk/postgis/postgis_brin.sql.in
Fixes #3956 for me
Modified: trunk/postgis/geography_brin.sql.in
--- trunk/postgis/geography_brin.sql.in 2018-01-09 15:04:03 UTC (rev 16231)
+++ trunk/postgis/geography_brin.sql.in 2018-01-09 15:04:21 UTC (rev 16232)
@@ -20,18 +20,7 @@
LANGUAGE 'c' IMMUTABLE STRICT;
--- logic to create missing brin operators
--- note we can't use CREATE IF NOT EXISTS since not currently supported for operators or families
--- an earlier 2.3+ might miss this if doing upgrade from < 9.5 to 9.5+
--- so we need to include this always for 9.5+
--- Intentionally not indenting DDL cause our uninstall process can't pick it up
--- also not dollar quoting functions inside DO since gets tripped up by perl upgrade script parser
-DO language 'plpgsql' $$
-BEGIN
- -- add geography brin ops if missing and are running a newer than 9.4 --
- -- use wildcard since if schema postgis is installed is not in search path, will have schema name in front
- IF NOT EXISTS(SELECT 1 from pg_operator WHERE oprname = '&&' AND
- oprleft::regtype::text LIKE '%gidx' AND oprright::regtype::text LIKE '%geography' ) THEN
-- Availability: 2.3.0
CREATE OPERATOR && (
LEFTARG = gidx,
@@ -43,7 +32,7 @@
CREATE OR REPLACE FUNCTION overlaps_geog(geography, gidx)
RETURNS boolean
-AS
+AS
'SELECT $2 OPERATOR(@extschema at .&&) $1;'
LANGUAGE SQL IMMUTABLE STRICT;
@@ -68,9 +57,6 @@
-CREATE OPERATOR FAMILY brin_geography_inclusion_ops USING brin;
--- Availability: 2.3.0
CREATE OR REPLACE FUNCTION geog_brin_inclusion_add_value(internal, internal, internal, internal) RETURNS boolean
AS 'MODULE_PATHNAME','geog_brin_inclusion_add_value'
LANGUAGE 'c';
@@ -80,25 +66,14 @@
DEFAULT FOR TYPE geography
USING brin
FAMILY brin_geography_inclusion_ops AS
+ FUNCTION 1 brin_inclusion_opcinfo(internal),
+ FUNCTION 2 geog_brin_inclusion_add_value(internal, internal, internal, internal),
+ FUNCTION 3 brin_inclusion_consistent(internal, internal, internal),
+ FUNCTION 4 brin_inclusion_union(internal, internal, internal),
OPERATOR 3 &&(geography, geography),
- FUNCTION 1 brin_inclusion_opcinfo(internal) ,
- FUNCTION 2 geog_brin_inclusion_add_value(internal, internal, internal, internal) ,
- FUNCTION 3 brin_inclusion_consistent(internal, internal, internal) ,
- FUNCTION 4 brin_inclusion_union(internal, internal, internal) ,
+ OPERATOR 3 &&(geography, gidx),
+ OPERATOR 3 &&(gidx, geography),
+ OPERATOR 3 &&(gidx, gidx),
STORAGE gidx;
-ALTER OPERATOR FAMILY brin_geography_inclusion_ops USING brin ADD
- OPERATOR 3 &&(gidx, geography),
- OPERATOR 3 &&(geography, gidx),
- OPERATOR 3 &&(gidx, gidx);
- END IF;
-END;
--- END
-#endif
\ No newline at end of file
+#endif
Modified: trunk/postgis/postgis_brin.sql.in
--- trunk/postgis/postgis_brin.sql.in 2018-01-09 15:04:03 UTC (rev 16231)
+++ trunk/postgis/postgis_brin.sql.in 2018-01-09 15:04:21 UTC (rev 16232)
@@ -44,17 +44,6 @@
AS 'MODULE_PATHNAME','gserialized_contains_box2df_box2df_2d'
-BEGIN
- -- add geometry brin ops if missing and are running a newer than 9.4 --
- -- use wildcard since if schema postgis is installed in is not in search path, will have schema name in front
- IF NOT EXISTS(SELECT 1 from pg_operator WHERE oprname = '~' AND
- oprleft::regtype::text LIKE '%box2df' AND oprright::regtype::text LIKE '%geometry' ) THEN
CREATE OPERATOR ~ (
LEFTARG = box2df,
@@ -62,10 +51,6 @@
PROCEDURE = contains_2d,
COMMUTATOR = @
- END IF;
- IF NOT EXISTS(SELECT 1 from pg_operator WHERE oprname = '@' AND
CREATE OPERATOR @ (
@@ -86,7 +71,7 @@
CREATE OR REPLACE FUNCTION contains_2d(geometry, box2df)
RETURNS boolean
-AS
+AS
'SELECT $2 OPERATOR(@extschema at .@) $1;'
@@ -100,7 +85,7 @@
CREATE OR REPLACE FUNCTION overlaps_2d(geometry, box2df)
RETURNS boolean
-AS
+AS
@@ -119,36 +104,35 @@
COMMUTATOR = ~,
PROCEDURE = is_contained_2d
+-- Availability: 2.3.0
LEFTARG = geometry,
RIGHTARG = box2df,
PROCEDURE = overlaps_2d,
COMMUTATOR = &&
LEFTARG = box2df,
RIGHTARG = box2df,
COMMUTATOR = &&
CREATE OPERATOR @ (
LEFTARG = box2df,
RIGHTARG = box2df,
PROCEDURE = is_contained_2d,
COMMUTATOR = ~
CREATE OPERATOR ~ (
LEFTARG = box2df,
RIGHTARG = box2df,
COMMUTATOR = @
- END IF;
-- nd operators --
@@ -165,25 +149,22 @@
AS 'MODULE_PATHNAME','gserialized_gidx_gidx_overlaps'
- IF NOT EXISTS(SELECT 1 from pg_operator WHERE oprname = '&&&' AND
- oprleft::regtype::text LIKE '%gidx' AND oprright::regtype::text LIKE '%geometry' ) THEN
CREATE OPERATOR &&& (
LEFTARG = gidx,
RIGHTARG = geometry,
PROCEDURE = overlaps_nd,
COMMUTATOR = &&&
CREATE OR REPLACE FUNCTION overlaps_nd(geometry, gidx)
RETURNS boolean
-AS
+AS
'SELECT $2 OPERATOR(@extschema at .&&&) $1;'
LEFTARG = geometry,
@@ -201,136 +182,91 @@
COMMUTATOR = &&&
- END IF;
-- Create operator families --
-- 2D case --
- IF NOT EXISTS(SELECT 1 FROM pg_opfamily WHERE opfname = 'brin_geometry_inclusion_ops_2d') THEN
-CREATE OPERATOR FAMILY brin_geometry_inclusion_ops_2d USING brin;
- END IF;
CREATE OR REPLACE FUNCTION geom2d_brin_inclusion_add_value(internal, internal, internal, internal) RETURNS boolean
AS 'MODULE_PATHNAME','geom2d_brin_inclusion_add_value'
LANGUAGE 'c';
CREATE OR REPLACE FUNCTION geom3d_brin_inclusion_add_value(internal, internal, internal, internal) RETURNS boolean
AS 'MODULE_PATHNAME','geom3d_brin_inclusion_add_value'
LANGUAGE 'c';
CREATE OR REPLACE FUNCTION geom4d_brin_inclusion_add_value(internal, internal, internal, internal) RETURNS boolean
AS 'MODULE_PATHNAME','geom4d_brin_inclusion_add_value'
LANGUAGE 'c';
- IF NOT EXISTS(SELECT 1 FROM pg_opclass WHERE opcname = 'brin_geometry_inclusion_ops_2d') THEN
CREATE OPERATOR CLASS brin_geometry_inclusion_ops_2d
DEFAULT FOR TYPE geometry
USING brin
FAMILY brin_geometry_inclusion_ops_2d AS
+ FUNCTION 2 geom2d_brin_inclusion_add_value(internal, internal, internal, internal),
+ OPERATOR 3 &&(box2df, box2df),
+ OPERATOR 3 &&(box2df, geometry),
+ OPERATOR 3 &&(geometry, box2df),
OPERATOR 3 &&(geometry, geometry),
+ OPERATOR 7 ~(box2df, box2df),
+ OPERATOR 7 ~(box2df, geometry),
+ OPERATOR 7 ~(geometry, box2df),
OPERATOR 7 ~(geometry, geometry),
+ OPERATOR 8 @(box2df, box2df);
+ OPERATOR 8 @(box2df, geometry),
+ OPERATOR 8 @(geometry, box2df),
OPERATOR 8 @(geometry, geometry),
- FUNCTION 2 geom2d_brin_inclusion_add_value(internal, internal, internal, internal) ,
STORAGE box2df;
-ALTER OPERATOR FAMILY brin_geometry_inclusion_ops_2d USING brin ADD
- OPERATOR 3 &&(box2df, geometry),
- OPERATOR 7 ~(box2df, geometry),
- OPERATOR 8 @(box2df, geometry),
- OPERATOR 3 &&(geometry, box2df),
- OPERATOR 7 ~(geometry, box2df),
- OPERATOR 8 @(geometry, box2df),
- OPERATOR 3 &&(box2df, box2df),
- OPERATOR 7 ~(box2df, box2df),
- OPERATOR 8 @(box2df, box2df);
- END IF;
-- 3D case --
- IF NOT EXISTS(SELECT 1 FROM pg_opfamily WHERE opfname = 'brin_geometry_inclusion_ops_3d') THEN
-CREATE OPERATOR FAMILY brin_geometry_inclusion_ops_3d USING brin;
- END IF;
- IF NOT EXISTS(SELECT 1 FROM pg_opclass WHERE opcname = 'brin_geometry_inclusion_ops_3d') THEN
CREATE OPERATOR CLASS brin_geometry_inclusion_ops_3d
FOR TYPE geometry
USING brin
FAMILY brin_geometry_inclusion_ops_3d AS
- OPERATOR 3 &&&(geometry, geometry),
- FUNCTION 2 geom3d_brin_inclusion_add_value(internal, internal, internal, internal) ,
+ FUNCTION 2 geom3d_brin_inclusion_add_value(internal, internal, internal, internal),
+ OPERATOR 3 &&&(geometry, geometry),
+ OPERATOR 3 &&&(geometry, gidx),
+ OPERATOR 3 &&&(gidx, geometry),
+ OPERATOR 3 &&&(gidx, gidx),
STORAGE gidx;
-ALTER OPERATOR FAMILY brin_geometry_inclusion_ops_3d USING brin ADD
- OPERATOR 3 &&&(gidx, geometry),
- OPERATOR 3 &&&(geometry, gidx),
- OPERATOR 3 &&&(gidx, gidx);
- END IF;
-- 4D case --
- IF NOT EXISTS(SELECT 1 FROM pg_opfamily WHERE opfname = 'brin_geometry_inclusion_ops_4d') THEN
-CREATE OPERATOR FAMILY brin_geometry_inclusion_ops_4d USING brin;
CREATE OPERATOR CLASS brin_geometry_inclusion_ops_4d
FOR TYPE geometry
USING brin
FAMILY brin_geometry_inclusion_ops_4d AS
+ FUNCTION 2 geom4d_brin_inclusion_add_value(internal, internal, internal, internal),
- FUNCTION 2 geom4d_brin_inclusion_add_value(internal, internal, internal, internal) ,
STORAGE gidx;
-ALTER OPERATOR FAMILY brin_geometry_inclusion_ops_4d USING brin ADD
- END IF;
--- END
-END;
-- BRIN support end
-#endif
+#endif
