[postgis-tickets] r16237 - Upgrade SFCGAL too when requested
Sandro Santilli
strk at kbt.io
Tue Jan 9 10:06:43 PST 2018
Author: strk
Date: 2018-01-09 10:06:42 -0800 (Tue, 09 Jan 2018)
New Revision: 16237
trunk/regress/run_test.pl
Might help with https://debbie.postgis.net/job/PostGIS_Regress/8247/console
Modified: trunk/regress/run_test.pl
--- trunk/regress/run_test.pl 2018-01-09 17:51:22 UTC (rev 16236)
+++ trunk/regress/run_test.pl 2018-01-09 18:06:42 UTC (rev 16237)
@@ -1401,6 +1401,22 @@
die "$script not found\n";
+ if ( $OPT_WITH_SFCGAL )
+ my $script = `ls ${STAGED_SCRIPTS_DIR}/sfcgal_upgrade.sql`;
+ chomp($script);
+ if ( -e $script )
+ print "Upgrading sfcgal\n";
+ load_sql_file($script);
+ else
+ die "$script not found\n";
return 1;
@@ -1437,6 +1453,17 @@
+ my $sql = "ALTER EXTENSION postgis_sfcgal UPDATE TO '${nextver}'";
+ $cmd = "psql $psql_opts -c \"" . $sql . "\" $DB >> $REGRESS_LOG 2>&1";
+ $rv = system($cmd);
+ if ( $rv ) {
+ fail "Error encountered creating EXTENSION POSTGIS_SFCGAL", $REGRESS_LOG;
+ die;
return 1;
