[postgis-tickets] r16247 - Generalize upgrade paths extension installs
Sandro Santilli
strk at kbt.io
Wed Jan 10 03:35:23 PST 2018
Author: strk
Date: 2018-01-10 03:35:22 -0800 (Wed, 10 Jan 2018)
New Revision: 16247
Added:
trunk/extensions/upgrade-paths-rules.mk
trunk/extensions/postgis/Makefile.in
trunk/extensions/postgis_topology/Makefile.in
Modified: trunk/extensions/postgis/Makefile.in
--- trunk/extensions/postgis/Makefile.in 2018-01-09 20:52:25 UTC (rev 16246)
+++ trunk/extensions/postgis/Makefile.in 2018-01-10 11:35:22 UTC (rev 16247)
@@ -135,31 +135,8 @@
printf '\\echo Use "CREATE EXTENSION $(EXTENSION)" to load this file. \\quit\n' > $@
cat $^ >> $@
-EXTDIR=$(DESTDIR)$(datadir)/$(datamoduledir)
+include ../upgrade-paths-rules.mk
-install: install-upgrade-paths
-# The "next" lines are a cludge to allow upgrading between different
-# revisions of the same version
-install-upgrade-paths:
- tpl='$(EXTENSION)--ANY--$(EXTVERSION).sql'; \
- $(INSTALL_DATA) sql/$${tpl} "$(EXTDIR)/$${tpl}"; \
- ln -fs "$${tpl}" $(EXTDIR)/$(EXTENSION)--$(EXTVERSION)--$(EXTVERSION)next.sql; \
- ln -fs "$${tpl}" $(EXTDIR)/$(EXTENSION)--$(EXTVERSION)next--$(EXTVERSION).sql; \
- for OLD_VERSION in $(UPGRADEABLE_VERSIONS); do \
- ln -fs "$${tpl}" $(EXTDIR)/$(EXTENSION)--$$OLD_VERSION--$(EXTVERSION).sql; \
- done
-uninstall: uninstall-upgrade-paths
-INSTALLED_UPGRADE_SCRIPTS = \
- $(wildcard $(EXTDIR)/*$(EXTVERSION).sql) \
- $(wildcard $(EXTDIR)/*$(EXTVERSION)next.sql) \
- $(NULL)
-uninstall-upgrade-paths:
- rm -f $(INSTALLED_UPGRADE_SCRIPTS)
distclean: clean
rm -f Makefile
Modified: trunk/extensions/postgis_topology/Makefile.in
--- trunk/extensions/postgis_topology/Makefile.in 2018-01-09 20:52:25 UTC (rev 16246)
+++ trunk/extensions/postgis_topology/Makefile.in 2018-01-10 11:35:22 UTC (rev 16247)
@@ -81,34 +81,8 @@
sql/$(EXTENSION)--ANY--$(EXTVERSION).sql: $(EXTENSION_UPGRADE_SCRIPTS)
cat $(EXTENSION_UPGRADE_SCRIPTS) > $@
- done
- $(NULL)
-DATA = $(wildcard sql/*--*.sql)
-EXTRA_CLEAN += sql/$(EXTENSION)--$(EXTVERSION).sql sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql
distclean: clean
rm Makefile
Added: trunk/extensions/upgrade-paths-rules.mk
--- trunk/extensions/upgrade-paths-rules.mk (rev 0)
+++ trunk/extensions/upgrade-paths-rules.mk 2018-01-10 11:35:22 UTC (rev 16247)
@@ -0,0 +1,24 @@
+EXTDIR=$(DESTDIR)$(datadir)/$(datamoduledir)
+install: install-upgrade-paths
+# The "next" lines are a cludge to allow upgrading between different
+# revisions of the same version
+install-upgrade-paths:
+ tpl='$(EXTENSION)--ANY--$(EXTVERSION).sql'; \
+ $(INSTALL_DATA) sql/$${tpl} "$(EXTDIR)/$${tpl}"; \
+ ln -fs "$${tpl}" $(EXTDIR)/$(EXTENSION)--$(EXTVERSION)--$(EXTVERSION)next.sql; \
+ ln -fs "$${tpl}" $(EXTDIR)/$(EXTENSION)--$(EXTVERSION)next--$(EXTVERSION).sql; \
+ for OLD_VERSION in $(UPGRADEABLE_VERSIONS); do \
+ ln -fs "$${tpl}" $(EXTDIR)/$(EXTENSION)--$$OLD_VERSION--$(EXTVERSION).sql; \
+ done
+uninstall: uninstall-upgrade-paths
+INSTALLED_UPGRADE_SCRIPTS = \
+ $(wildcard $(EXTDIR)/*$(EXTVERSION).sql) \
+ $(wildcard $(EXTDIR)/*$(EXTVERSION)next.sql) \
+ $(NULL)
+uninstall-upgrade-paths:
+ rm -f $(INSTALLED_UPGRADE_SCRIPTS)
