[postgis-tickets] r16254 - Formatting only before toucing Encoded Polyline logic.
Darafei
komzpa at gmail.com
Thu Jan 11 04:46:28 PST 2018
Author: komzpa
Date: 2018-01-11 04:46:27 -0800 (Thu, 11 Jan 2018)
New Revision: 16254
trunk/liblwgeom/cunit/cu_out_encoded_polyline.c
trunk/liblwgeom/lwout_encoded_polyline.c
References #3982
Modified: trunk/liblwgeom/cunit/cu_out_encoded_polyline.c
--- trunk/liblwgeom/cunit/cu_out_encoded_polyline.c 2018-01-11 05:57:47 UTC (rev 16253)
+++ trunk/liblwgeom/cunit/cu_out_encoded_polyline.c 2018-01-11 12:46:27 UTC (rev 16254)
@@ -1,15 +1,15 @@
-* PostGIS - Spatial Types for PostgreSQL
-* http://postgis.net
-* Copyright 2014 Kashif Rasul <kashif.rasul at gmail.com> and
-* Shoaib Burq <saburq at gmail.com>
-* This is free software; you can redistribute and/or modify it under
-* the terms of the GNU General Public Licence. See the COPYING file.
+ * PostGIS - Spatial Types for PostgreSQL
+ * http://postgis.net
+ * Copyright 2014 Kashif Rasul <kashif.rasul at gmail.com> and
+ * Shoaib Burq <saburq at gmail.com>
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU General Public Licence. See the COPYING file.
#include <stdio.h>
#include <stdlib.h>
@@ -19,16 +19,16 @@
#include "liblwgeom_internal.h"
#include "cu_tester.h"
-static void do_encoded_polyline_test(char * in, int precision, char * out)
+static void
+do_encoded_polyline_test(char* in, int precision, char* out)
- LWGEOM *g;
- char * h;
+ LWGEOM* g;
+ char* h;
g = lwgeom_from_wkt(in, LW_PARSER_CHECK_NONE);
h = lwgeom_to_encoded_polyline(g, precision);
- if (strcmp(h, out))
- fprintf(stderr, "\nIn: %s\nOut: %s\nTheo: %s\n", in, h, out);
+ if (strcmp(h, out)) fprintf(stderr, "\nIn: %s\nOut: %s\nTheo: %s\n", in, h, out);
CU_ASSERT_STRING_EQUAL(h, out);
@@ -36,66 +36,54 @@
lwfree(h);
-static void out_encoded_polyline_test_geoms(void)
+static void
+out_encoded_polyline_test_geoms(void)
/* Magic Linestring */
- do_encoded_polyline_test(
- "SRID=4326;LINESTRING(33.6729 38.7071,33.6692 38.701,33.6673 38.6972,33.6626 38.6871)",
- 5,
- "k~fkFsvolEbe at bVvVzJb~@j\\");
- return;
+ do_encoded_polyline_test("SRID=4326;LINESTRING(33.6729 38.7071,33.6692 38.701,33.6673 38.6972,33.6626 38.6871)",
+ 5,
+ "k~fkFsvolEbe at bVvVzJb~@j\\");
+ return;
/* Linestring */
- "LINESTRING(-120.2 38.5,-120.95 40.7,-126.453 43.252)",
- 5,
- "_p~iF~ps|U_ulLnnqC_mqNvxq`@");
+ "LINESTRING(-120.2 38.5,-120.95 40.7,-126.453 43.252)", 5, "_p~iF~ps|U_ulLnnqC_mqNvxq`@");
/* MultiPoint */
- "MULTIPOINT(-120.2 38.5,-120.95 40.7)",
- 5,
- "_p~iF~ps|U_ulLnnqC");
+ do_encoded_polyline_test("MULTIPOINT(-120.2 38.5,-120.95 40.7)", 5, "_p~iF~ps|U_ulLnnqC");
-static void out_encoded_polyline_test_srid(void)
+static void
+out_encoded_polyline_test_srid(void)
/* SRID - with PointArray */
- "SRID=4326;LINESTRING(0 1,2 3)",
- 5,
- "_ibE?_seK_seK");
+ do_encoded_polyline_test("SRID=4326;LINESTRING(0 1,2 3)", 5, "_ibE?_seK_seK");
/* wrong SRID */
- "SRID=4327;LINESTRING(0 1,2 3)",
- 5,
- "_ibE?_seK_seK");
+ do_encoded_polyline_test("SRID=4327;LINESTRING(0 1,2 3)", 5, "_ibE?_seK_seK");
-static void out_encoded_polyline_test_precision(void)
+static void
+out_encoded_polyline_test_precision(void)
/* Linestring */
- "LINESTRING(-0.250691 49.283048,-0.250633 49.283376,-0.250502 49.283972,-0.251245 49.284028,-0.251938 49.284232,-0.251938 49.2842)",
- 6,
- "o}~~|AdshNoSsBgd at eGoBlm@wKhj@~@?");
+ do_encoded_polyline_test("LINESTRING(-0.250691 49.283048,-0.250633 49.283376,-0.250502 49.283972,-0.251245 "
+ "49.284028,-0.251938 49.284232,-0.251938 49.2842)",
+ 6,
+ "o}~~|AdshNoSsBgd at eGoBlm@wKhj@~@?");
/* MultiPoint */
- 3,
- "gejAnwiFohCzm@");
+ do_encoded_polyline_test("MULTIPOINT(-120.2 38.5,-120.95 40.7)", 3, "gejAnwiFohCzm@");
** Used by test harness to register the tests in this file.
void out_encoded_polyline_suite_setup(void);
-void out_encoded_polyline_suite_setup(void)
+void
+out_encoded_polyline_suite_setup(void)
CU_pSuite suite = CU_add_suite("encoded_polyline_output", NULL, NULL);
PG_ADD_TEST(suite, out_encoded_polyline_test_geoms);
Modified: trunk/liblwgeom/lwout_encoded_polyline.c
--- trunk/liblwgeom/lwout_encoded_polyline.c 2018-01-11 05:57:47 UTC (rev 16253)
+++ trunk/liblwgeom/lwout_encoded_polyline.c 2018-01-11 12:46:27 UTC (rev 16254)
@@ -18,21 +18,20 @@
#include "stringbuffer.h"
-static char * lwline_to_encoded_polyline(const LWLINE*, int precision);
-static char * lwmmpoint_to_encoded_polyline(const LWMPOINT*, int precision);
-static char * pointarray_to_encoded_polyline(const POINTARRAY*, int precision);
+static char* lwline_to_encoded_polyline(const LWLINE*, int precision);
+static char* lwmmpoint_to_encoded_polyline(const LWMPOINT*, int precision);
+static char* pointarray_to_encoded_polyline(const POINTARRAY*, int precision);
/* takes a GEOMETRY and returns an Encoded Polyline representation */
-extern char *
-lwgeom_to_encoded_polyline(const LWGEOM *geom, int precision)
+extern char*
+lwgeom_to_encoded_polyline(const LWGEOM* geom, int precision)
int type = geom->type;
switch (type)
@@ -47,48 +46,48 @@
-static
-char * lwline_to_encoded_polyline(const LWLINE *line, int precision)
+static char*
+lwline_to_encoded_polyline(const LWLINE* line, int precision)
return pointarray_to_encoded_polyline(line->points, precision);
-static
-char * lwmmpoint_to_encoded_polyline(const LWMPOINT *mpoint, int precision)
+static char*
+lwmmpoint_to_encoded_polyline(const LWMPOINT* mpoint, int precision)
- LWLINE *line = lwline_from_lwmpoint(mpoint->srid, mpoint);
- char *encoded_polyline = lwline_to_encoded_polyline(line, precision);
+ LWLINE* line = lwline_from_lwmpoint(mpoint->srid, mpoint);
+ char* encoded_polyline = lwline_to_encoded_polyline(line, precision);
lwline_free(line);
return encoded_polyline;
-static
-char * pointarray_to_encoded_polyline(const POINTARRAY *pa, int precision)
+static char*
+pointarray_to_encoded_polyline(const POINTARRAY* pa, int precision)
int i;
- const POINT2D *prevPoint;
- int *delta = lwalloc(2*sizeof(int)*pa->npoints);
- char *encoded_polyline = NULL;
- stringbuffer_t *sb;
- double scale = pow(10,precision);
+ const POINT2D* prevPoint;
+ int* delta = lwalloc(2 * sizeof(int) * pa->npoints);
+ char* encoded_polyline = NULL;
+ stringbuffer_t* sb;
+ double scale = pow(10, precision);
/* Take the double value and multiply it by 1x10^precision, rounding the result */
prevPoint = getPoint2d_cp(pa, 0);
- delta[0] = round(prevPoint->y*scale);
- delta[1] = round(prevPoint->x*scale);
+ delta[0] = round(prevPoint->y * scale);
+ delta[1] = round(prevPoint->x * scale);
/* points only include the offset from the previous point */
- for (i=1; i<pa->npoints; i++)
+ for (i = 1; i < pa->npoints; i++)
- const POINT2D *point = getPoint2d_cp(pa, i);
- delta[2*i] = round(point->y*scale) - round(prevPoint->y*scale);
- delta[(2*i)+1] = round(point->x*scale) - round(prevPoint->x*scale);
+ const POINT2D* point = getPoint2d_cp(pa, i);
+ delta[2 * i] = round(point->y * scale) - round(prevPoint->y * scale);
+ delta[(2 * i) + 1] = round(point->x * scale) - round(prevPoint->x * scale);
prevPoint = point;
/* value to binary: a negative value must be calculated using its two's complement */
- for (i=0; i<pa->npoints*2; i++)
+ for (i = 0; i < pa->npoints * 2; i++)
/* Multiply by 2 for a signed left shift */
delta[i] *= 2;
@@ -99,11 +98,12 @@
sb = stringbuffer_create();
int numberToEncode = delta[i];
- while (numberToEncode >= 0x20) {
+ while (numberToEncode >= 0x20)
/* Place the 5-bit chunks into reverse order or
each value with 0x20 if another bit chunk follows and add 63*/
int nextValue = (0x20 | (numberToEncode & 0x1f)) + 63;
