[postgis-tickets] [PostGIS] #3975: ST_Transform references spatial_ref_sys without schema
trac at osgeo.org
Thu Jan 11 08:46:46 PST 2018
Reporter: javitonino | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.4.3
Component: postgis | Version: 2.4.x
Resolution: | Keywords:
Comment (by pramsey):
Fix 3:
* From my colleague @javitonino, we can just add `SET SEARCH_PATH =
@extschema@, pg_catalog` in the function definition itself. As the manual
for https://www.postgresql.org/docs/9.5/static/sql-createfunction.html
create function notes, we can add `SET` clauses there.
Unless someone has a screaming reason why this is not right, I think
`st_transform` and `postgis_transform_geometry` can be upgraded with this
small fix, and that should probably be backported as well, so other fresh
installs get the right schema qualifications right up fron..
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3975#comment:3>
