[postgis-tickets] [PostGIS] #3975: ST_Transform references spatial_ref_sys without schema
trac at osgeo.org
Thu Jan 11 09:33:12 PST 2018
Reporter: javitonino | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.4.3
Component: postgis | Version: 2.4.x
Resolution: | Keywords:
Comment (by robe):
Replying to [comment:2 pramsey]:
> * Potentially cleaner but still ugly variant: change the signature of
`st_transform` and `postgis_transform_geometry` to have an extra 'schema'
parameter that has a default value of @extschema@, then we can avoid the
extra level of indirection and get the install schema injected still.
Depends on defaults working and involves changing signature of existing
heavily used function.
Wondering is it any easier to look this value up in a GUC variable than
going thru FunctionCallInfo.
My thought is on install or upgrade of PostGIS, we can have our code set a
guc variable to @extschema at .
Then if that guc variable is set, our SPI queries will use the GUC
variable
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3975#comment:5>
