[postgis-tickets] r16261 - Do not try to install sfcgal extension when not available
Sandro Santilli
strk at kbt.io
Thu Jan 11 01:36:35 PST 2018
Author: strk
Date: 2018-01-11 13:36:35 -0800 (Thu, 11 Jan 2018)
New Revision: 16261
trunk/regress/run_test.pl
When testing upgrade from a version < 2.2.0 and requesting sfcgal
avoid to create it initially and create it directly at upgrade
time.
Modified: trunk/regress/run_test.pl
--- trunk/regress/run_test.pl 2018-01-11 21:36:27 UTC (rev 16260)
+++ trunk/regress/run_test.pl 2018-01-11 21:36:35 UTC (rev 16261)
@@ -258,6 +258,21 @@
exit(1);
+sub semver_lessthan
+ my ($a,$b) = @_;
+ my @acomp = split(/\./, $a);
+ my @bcomp = split(/\./, $b);
+ foreach my $ac (@acomp) {
+ my $bc = shift(@bcomp);
+ return 0 if not defined($bc); # $b has less components
+ return 1 if ( $ac < $bc ); # $a is less than $b
+ return 0 if ( $ac > $bc ); # $a is not less than $b
+ # $a is equal to $b so far, if $b has more elements,
+ # it is bigger
+ return @bcomp ? 1 : 0;
sub create_upgrade_test_objects
@@ -1301,16 +1316,24 @@
if ( $OPT_WITH_SFCGAL )
- my $sql = "CREATE EXTENSION postgis_sfcgal";
- if ( $OPT_UPGRADE_FROM ) {
- $sql .= " VERSION '" . $OPT_UPGRADE_FROM . "'";
- $cmd = "psql $psql_opts -c \"" . $sql . "\" $DB >> $REGRESS_LOG 2>&1";
- $rv = system($cmd);
- if ( $rv ) {
- fail "Error encountered creating EXTENSION POSTGIS_SFCGAL", $REGRESS_LOG;
- die;
+ do {
+ my $sql = "CREATE EXTENSION postgis_sfcgal";
+ if ( $OPT_UPGRADE_FROM ) {
+ if ( semver_lessthan($OPT_UPGRADE_FROM, "2.2.0") )
+ print "NOTICE: skipping SFCGAL extension create "
+ . "as not available in version $OPT_UPGRADE_FROM\n";
+ last;
+ $sql .= " VERSION '" . $OPT_UPGRADE_FROM . "'";
+ $cmd = "psql $psql_opts -c \"" . $sql . "\" $DB >> $REGRESS_LOG 2>&1";
+ $rv = system($cmd);
+ if ( $rv ) {
+ fail "Error encountered creating EXTENSION POSTGIS_SFCGAL", $REGRESS_LOG;
+ die;
+ } while (0);
return 1;
@@ -1452,7 +1475,16 @@
- my $sql = "ALTER EXTENSION postgis_sfcgal UPDATE TO '${nextver}'";
+ print "NOTICE: installing SFCGAL extension on upgrade "
+ . "as it was not available in version $OPT_UPGRADE_FROM\n";
+ my $sql = "CREATE EXTENSION postgis_sfcgal VERSION '${nextver}'";
+ else
+ my $sql = "ALTER EXTENSION postgis_sfcgal UPDATE TO '${nextver}'";
$rv = system($cmd);
if ( $rv ) {
