[postgis-tickets] [PostGIS] #3822: Have postgis_full_version() also denote which version of PostgreSQL the scripts were built against
PostGIS trac at osgeo.org
Fri Jan 12 01:38:18 PST 2018
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  closed
  Priority:  medium   |  Milestone:  PostGIS 2.4.0
 Component:  postgis  |    Version:  2.3.x
Resolution:  fixed    |   Keywords:
Comment (by strk):
 In [changeset:"16267" 16267]:
 #!CommitTicketReference repository="" revision="16267"
 Add check for PostgreSQL version compatibility in postgis_full_version
 Adds _postgis_scripts_pgsql_version() and _postgis_pgsql_version()
 internal functions, each returning an encoded version number,
 and has postgis_full_version() compare running vs. build-time used
 Always show PGSQL version scripts were built against
 References #3822 for 2.3 branch
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3822#comment:9>
