[postgis-tickets] r16271 - 2.4 fix, st_transform does not qualify query to spatial_ref_sys (references #3975)
Paul Ramsey
pramsey at cleverelephant.ca
Fri Jan 12 05:47:51 PST 2018
Author: pramsey
Date: 2018-01-12 05:47:51 -0800 (Fri, 12 Jan 2018)
New Revision: 16271
branches/2.4/NEWS
branches/2.4/libpgcommon/lwgeom_pg.h
branches/2.4/libpgcommon/lwgeom_transform.c
branches/2.4/libpgcommon/lwgeom_transform.h
Modified: branches/2.4/NEWS
--- branches/2.4/NEWS 2018-01-12 13:34:32 UTC (rev 16270)
+++ branches/2.4/NEWS 2018-01-12 13:47:51 UTC (rev 16271)
@@ -11,6 +11,8 @@
- #3956, Brin opclass object does not upgrade properly (Sandro Santilli)
- #3982, ST_AsEncodedPolyline supports LINESTRING EMPTY and MULTIPOINT EMPTY
(Darafei Praliaskouski)
+ - #3975, ST_Transform runs query on spatial_ref_sys without schema
+ qualification. May cause restore issues. (Paul Ramsey)
* Enhancements *
- #3944, Update to EPSG register v9.2 (Even Rouault)
Modified: branches/2.4/libpgcommon/lwgeom_pg.h
--- branches/2.4/libpgcommon/lwgeom_pg.h 2018-01-12 13:34:32 UTC (rev 16270)
+++ branches/2.4/libpgcommon/lwgeom_pg.h 2018-01-12 13:47:51 UTC (rev 16271)
@@ -18,6 +18,7 @@
#include "postgres.h"
#include "utils/geo_decls.h"
#include "fmgr.h"
+#include "utils/lsyscache.h"
#include "liblwgeom.h"
#include "pgsql_compat.h"
Modified: branches/2.4/libpgcommon/lwgeom_transform.c
--- branches/2.4/libpgcommon/lwgeom_transform.c 2018-01-12 13:34:32 UTC (rev 16270)
+++ branches/2.4/libpgcommon/lwgeom_transform.c 2018-01-12 13:47:51 UTC (rev 16271)
@@ -34,6 +34,15 @@
#include <errno.h>
+* Global variable to hold cached information about what
+* schema functions are installed in. Currently used by
+* SetSpatialRefSysSchema and GetProj4StringSPI
+static char *spatialRefSysSchema = NULL;
/* Expose an internal Proj function */
int pj_transform_nodatum(projPJ srcdefn, projPJ dstdefn, long point_count, int point_offset, double *x, double *y, double *z );
@@ -349,9 +358,25 @@
elog(ERROR, "GetProj4StringSPI: Could not connect to database using SPI");
- /* Execute the lookup query */
- snprintf(proj4_spi_buffer, 255, "SELECT proj4text FROM spatial_ref_sys WHERE srid = %d LIMIT 1", srid);
- spi_result = SPI_exec(proj4_spi_buffer, 1);
+ * This global is allocated in CacheMemoryContext (lifespan of this backend)
+ * and is set by SetSpatialRefSysSchema the first time
+ * that GetProjectionsUsingFCInfo is called.
+ if (spatialRefSysSchema)
+ /* Format the lookup query */
+ static char *proj_str_tmpl = "SELECT proj4text FROM %s.spatial_ref_sys WHERE srid = %d LIMIT 1";
+ snprintf(proj4_spi_buffer, 255, proj_str_tmpl, spatialRefSysSchema, srid);
+ else
+ static char *proj_str_tmpl = "SELECT proj4text FROM spatial_ref_sys WHERE srid = %d LIMIT 1";
+ snprintf(proj4_spi_buffer, 255, proj_str_tmpl, srid);
+ /* Execute the query, noting the readonly status of this SQL */
+ spi_result = SPI_execute(proj4_spi_buffer, true, 1);
/* Read back the PROJ4 text */
if (spi_result == SPI_OK_SELECT && SPI_processed > 0)
@@ -698,6 +723,30 @@
#endif
+* Given a function call context, figure out what namespace the
+* function is being called from, and copy that into a global
+* for use by GetProj4StringSPI
+static void
+SetSpatialRefSysSchema(FunctionCallInfo fcinfo)
+ char *nsp_name;
+ /* Schema info is already cached, we're done here */
+ if (spatialRefSysSchema) return;
+ /* For some reason we have a hobbled fcinfo/flinfo */
+ if (!fcinfo || !fcinfo->flinfo) return;
+ nsp_name = get_namespace_name(get_func_namespace(fcinfo->flinfo->fn_oid));
+ elog(DEBUG4, "%s located %s in namespace %s", __func__, get_func_name(fcinfo->flinfo->fn_oid), nsp_name);
+ spatialRefSysSchema = MemoryContextAlloc(CacheMemoryContext, strlen(nsp_name)+1);
+ strcpy(spatialRefSysSchema, nsp_name);
+ return;
int
GetProjectionsUsingFCInfo(FunctionCallInfo fcinfo, int srid1, int srid2, projPJ *pj1, projPJ *pj2)
@@ -706,6 +755,9 @@
/* Set the search path if we haven't already */
SetPROJ4LibPath();
+ /* Look up the spatial_ref_sys schema if we haven't already */
+ SetSpatialRefSysSchema(fcinfo);
/* get or initialize the cache for this round */
proj_cache = GetPROJ4Cache(fcinfo);
if ( !proj_cache )
Modified: branches/2.4/libpgcommon/lwgeom_transform.h
--- branches/2.4/libpgcommon/lwgeom_transform.h 2018-01-12 13:34:32 UTC (rev 16270)
+++ branches/2.4/libpgcommon/lwgeom_transform.h 2018-01-12 13:47:51 UTC (rev 16271)
@@ -23,7 +23,6 @@
char* GetProj4StringSPI(int srid);
void SetPROJ4LibPath(void) ;
* Opaque type to use in the projection cache API.
