[postgis-tickets] [PostGIS] #3985: Revise debbie's make tar ball scripts
PostGIS trac at osgeo.org
Fri Jan 12 22:46:05 PST 2018
 Reporter:  robe                   |      Owner:  robe
     Type:  defect                 |     Status:  assigned
 Priority:  blocker                |  Milestone:  PostGIS 2.4.3
Component:  build/upgrade/install  |    Version:  2.4.x
 Keywords:                         |
 I'm going to revise to have debbie's tar balls to be created as separate
 web_hook job in response to any branch creation or repo pull.
 I will also have script stored in repo and do the stuff she needs to do
 like configure the versions and then call the main make_dist.sh
 This will make the process more repeatable and maybe we can always have
 her do the builds and just copy down to test.
 Right now the tag is a manual job pull.
 Also since she will be doing the builds of tags all the time, that removes
 our individual desktop differences out of the equation.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3985>
