[postgis-tickets] r16281 - First draft
Regina Obe lr at pcorp.us
Fri Jan 12 10:59:35 PST 2018
Author: robe
Date: 2018-01-12 22:59:34 -0800 (Fri, 12 Jan 2018)
New Revision: 16281
Added:
   trunk/ci/debbie/postgis_make_dist.sh
First draft
References #3985
Added: trunk/ci/debbie/postgis_make_dist.sh
--- trunk/ci/debbie/postgis_make_dist.sh	                        (rev 0)
+++ trunk/ci/debbie/postgis_make_dist.sh	2018-01-13 06:59:34 UTC (rev 16281)
@@ -0,0 +1,30 @@
+#!/bin/bash
+set -e
+## begin variables passed in by jenkins
+export PG_VER=9.6
+# export PGPORT=8442
+export OS_BUILD=64
+# export POSTGIS_MAJOR_VERSION=2
+# export POSTGIS_MINOR_VERSION=2
+# export POSTGIS_MICRO_VERSION=0dev
+# export JENKINS_HOME=/var/lib/jenkins/workspace
+export GEOS_VER=3.6.2
+export GDAL_VER=2.2
+export WEB_DIR=/var/www/postgis_stuff/
+export PATH="${PGPATH}/bin:$PATH"
+export LD_LIBRARY_PATH="${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}/lib:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}/lib:${PGPATH}/lib"
+cd ../../
+$POSTGIS_MAJOR_VERSION=`grep ^POSTGIS_MAJOR_VERSION Version.config | cut -d= -f2`
+$POSTGIS_MINOR_VERSION=`grep ^POSTGIS_MINOR_VERSION Version.config | cut -d= -f2`
+$POSTGIS_MICRO_VERSION=`grep ^POSTGIS_MICRO_VERSION Version.config | cut -d= -f2`
+export CONFIGURE_ARGS=--with-pgconfig=${PROJECTS}/pg/rel/pg${PG_VER}w${OS_BUILD}/bin/pg_config \
+    --with-geosconfig=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}/bin/geos-config \
+    --with-gdalconfig=${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}/bin/gdal-config --with-sfcgal=/usr/bin/sfcgal-config \
+    --without-interrupt-tests \
+    --prefix=${PROJECTS}/pg/rel/pg${PG_VER}w${OS_BUILD}
+sh make_dist.sh
+cp $package $WEB_DIR
