[postgis-tickets] r16285 - Add step to make the PDF, html and other docs.
Regina Obe
lr at pcorp.us
Sat Jan 13 10:16:26 PST 2018
Author: robe
Date: 2018-01-13 10:16:26 -0800 (Sat, 13 Jan 2018)
New Revision: 16285
Added:
trunk/ci/debbie/postgis_release_docs.sh
trunk/ci/debbie/postgis_make_dist.sh
References #3985 for PostGIS 2.5 (trunk)
Modified: trunk/ci/debbie/postgis_make_dist.sh
--- trunk/ci/debbie/postgis_make_dist.sh 2018-01-13 18:01:51 UTC (rev 16284)
+++ trunk/ci/debbie/postgis_make_dist.sh 2018-01-13 18:16:26 UTC (rev 16285)
@@ -32,3 +32,4 @@
echo "The package name is $package"
cp $package $WEB_DIR
+sh ci/debbie/postgis_release_docs.sh
Added: trunk/ci/debbie/postgis_release_docs.sh
--- trunk/ci/debbie/postgis_release_docs.sh (rev 0)
+++ trunk/ci/debbie/postgis_release_docs.sh 2018-01-13 18:16:26 UTC (rev 16285)
@@ -0,0 +1,60 @@
+#!/bin/bash
+chmod -R 755 /var/www/postgis_docs/manual-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}
+export PG_VER=9.6
+# export PGPORT=8442
+export OS_BUILD=64
+# export POSTGIS_MAJOR_VERSION=2
+# export POSTGIS_MINOR_VERSION=2
+# export POSTGIS_MICRO_VERSION=0dev
+export PROJECTS=/var/lib/jenkins/workspace
+export GEOS_VER=3.6
+export GDAL_VER=2.2
+export WEB_DIR=/var/www/postgis_stuff
+export PATH="${PGPATH}/bin:$PATH"
+export LD_LIBRARY_PATH="${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}/lib:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}/lib:${PGPATH}/lib"
+POSTGIS_MAJOR_VERSION=`grep ^POSTGIS_MAJOR_VERSION Version.config | cut -d= -f2`
+POSTGIS_MINOR_VERSION=`grep ^POSTGIS_MINOR_VERSION Version.config | cut -d= -f2`
+POSTGIS_MICRO_VERSION=`grep ^POSTGIS_MICRO_VERSION Version.config | cut -d= -f2`
+echo $PATH
+sh autogen.sh
+if [ -f GNUMakefile ]; then
+ make distclean
+fi
+# --with-gdalconfig=${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}/bin/gdal-config
+# --without-raster
+CPPFLAGS="-I${PGPATH}/include" \
+LDFLAGS="-L${PGPATH}/lib" ./configure \
+ --with-pgconfig=${PGPATH}/bin/pg_config \
+ --with-geosconfig=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}/bin/geos-config \
+ --without-raster
+make clean
+cd doc
+mv postgis.xml postgis.xml.orig
+sed -e "s:</title>:</title><subtitle><subscript>SVN Revision (<emphasis>${POSTGIS_SVN_REVISION}</emphasis>)</subscript></subtitle>:" postgis.xml.orig > postgis.xml
+make pdf
+rm -rf images
+mkdir images
+cp html/images/* images
+make epub
+make -e chunked-html 2>&1 | tee -a doc-errors.log
+#make update-po
+#make -C po/it_IT/ local-html
+#make -C po/pt_BR/ local-html
+#make pdf-localized
+mv postgis.xml.orig postgis.xml
+mkdir -p /var/www/postgis_docs/manual-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}
+mkdir -p /var/www/postgis_docs/manual-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}/images
+cp -R html/*.* /var/www/postgis_docs/manual-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}
+cp -R html/images/* /var/www/postgis_docs/manual-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}/images
+cp -R *.pdf /var/www/postgis_stuff/
+cp -R *.epub /var/www/postgis_stuff/
