[postgis-tickets] r16287 - revise doc build to build html tar ball. Revise how to release to skip make dist and doc build, and to just have these downloaded from site
Regina Obe
lr at pcorp.us
Sat Jan 13 10:54:39 PST 2018
Author: robe
Date: 2018-01-13 10:54:39 -0800 (Sat, 13 Jan 2018)
New Revision: 16287
trunk/HOWTO_RELEASE
trunk/ci/debbie/postgis_release_docs.sh
References #3985 for PostGIS 2.5 (trunk)
Modified: trunk/HOWTO_RELEASE
--- trunk/HOWTO_RELEASE 2018-01-13 18:22:38 UTC (rev 16286)
+++ trunk/HOWTO_RELEASE 2018-01-13 18:54:39 UTC (rev 16287)
@@ -86,9 +86,11 @@
$ brev=x.x
$ rev=x.x.x
$ svn copy -m "Tagged release $rev" $base/branches/$brev $base/tags/$rev
-- Run: sh make_dist.sh $rev (or use debbie for this)
+- Run: sh make_dist.sh $rev (note, debbie should have already done this,
+ and the file will be waiting in postgis.net/stuff)
+- Documentation should also have been built and should be in postgis.net/stuff
- Build and test generated tarball (including extension upgrade)
-- Copy tarball to web site and edit downloads page
+- Copy tarball, pdf, doc-html.. to downloads.osgeo.org web site and edit downloads page
- Announce on e-mail
- postgis-users
- postgis-devel
@@ -96,9 +98,9 @@
- osgeo-discuss
- Update web sites
- PostGIS News
- - https://git.osgeo.org/gogs/postgis/postgis.net/src/master/_content/posts
+ - https://git.osgeo.org/gitea/postgis/postgis.net/src/master/_content/posts
a) create a new Post for current year making sure the page name starts with mm-dd
- b) Update links on https://git.osgeo.org/gogs/postgis/postgis.net/src/master/_content/pages/source.html
+ b) Update links on https://git.osgeo.org/gitea/postgis/postgis.net/src/master/_content/pages/source.html
c) commit and wait 5 minutes to see changes on website
- PostGIS doc release versioned doc - http://postgis.net/documentation/
(For building pdf, debbie has tagged jobs
Modified: trunk/ci/debbie/postgis_release_docs.sh
--- trunk/ci/debbie/postgis_release_docs.sh 2018-01-13 18:22:38 UTC (rev 16286)
+++ trunk/ci/debbie/postgis_release_docs.sh 2018-01-13 18:54:39 UTC (rev 16287)
@@ -1,5 +1,4 @@
#!/bin/bash
-chmod -R 755 /var/www/postgis_docs/manual-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}
export PG_VER=9.6
# export PGPORT=8442
export OS_BUILD=64
@@ -20,6 +19,8 @@
POSTGIS_MAJOR_VERSION=`grep ^POSTGIS_MAJOR_VERSION Version.config | cut -d= -f2`
POSTGIS_MINOR_VERSION=`grep ^POSTGIS_MINOR_VERSION Version.config | cut -d= -f2`
POSTGIS_MICRO_VERSION=`grep ^POSTGIS_MICRO_VERSION Version.config | cut -d= -f2`
+chmod -R 755 /var/www/postgis_docs/manual-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}
echo $PATH
sh autogen.sh
@@ -49,6 +50,14 @@
cp html/images/* images
make epub
make -e chunked-html 2>&1 | tee -a doc-errors.log
+make update-po
+make -C po/ja/ local-html
+make -C po/de/ local-html
+make -C po/pt_BR/ local-html
+make -C po/ko_KR/ local-html
+package="doc-html-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}.tar.gz"
+export outdir=html
+tar -czf "$package" --exclude='.svn' --exclude='.git' --exclude='image_src' "$outdir"
#make update-po
#make -C po/it_IT/ local-html
#make -C po/pt_BR/ local-html
@@ -62,3 +71,4 @@
cp -R *.pdf /var/www/postgis_stuff/
cp -R *.epub /var/www/postgis_stuff/
+cp -R $package /var/www/postgis_stuff/
