[postgis-tickets] [PostGIS] #3985: Revise debbie's make tar ball and doc build scripts and store as part of main repo
trac at osgeo.org
Sat Jan 13 11:44:33 PST 2018
main repo
Reporter: robe | Owner: robe
Type: defect | Status: assigned
Priority: blocker | Milestone: PostGIS 2.4.3
Component: build/upgrade/install | Version: 2.4.x
Resolution: | Keywords:
Comment (by robe):
I have now for 2.4, 2.5 any pushes or even taggings, should force debbie
to generate a tarball and docs. Which will be available in
http://postgis.net/stuff as soon as she is done.
I'm going to back port to 2.3 as well.
This means there should no longer be a need for anyone to build the
tarballs locally, thus removing the idiosyncrasies of our machines out of
the picture.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3985#comment:9>
