[postgis-tickets] [PostGIS] #3990: ST_AsMVTGeom fails on OS X (and Heroku)
PostGIS trac at osgeo.org
Sun Jan 14 15:35:12 PST 2018
 Reporter:  tyrauber  |      Owner:  pramsey
     Type:  defect    |     Status:  new
 Priority:  medium    |  Milestone:  PostGIS 2.4.3
Component:  postgis   |    Version:  2.4.x
 Keywords:            |
 ST_AsMVT and ST_AsMVTGeom look like good additions to PostGis.
 Unfortunately, ST_AsMVTGeom fails on both OSX and heroku.
 On OS X I upgraded postgres and postgis using brew and installed
 protobuf-c.
 Running the documentation query:
 SELECT ST_AsMVT(q, 'test', 4096, 'geom') FROM (SELECT 1 AS c1,
     ST_AsMVTGeom(ST_GeomFromText('POLYGON ((35 10, 45 45, 15 40, 10 20, 35
 10), (20 30, 35 35, 30 20, 20 30))'),
     ST_MakeBox2D(ST_Point(0, 0), ST_Point(4096, 4096)), 4096, 0, false) AS
 geom) AS q;
 Results in the error.
 ERROR:  Missing libprotobuf-c
 The same error is seen on Heroku.
 OS X Platform version:
 # psql (10.1)
 # POSTGIS="2.4.2 r16113" PGSQL="100" GEOS="3.6.2-CAPI-1.10.2 4d2925d6"
 PROJ="Rel. 4.9.3, 15 August 2016" GDAL="GDAL 1.11.5, released 2016/07/01"
 LIBXML="2.9.7" LIBJSON="0.12.1” RASTER
 $ libprotoc 2.6.0
 Heroku:
 # psql (10.1)
 #  POSTGIS="2.4.2 r16113" PGSQL="100" GEOS="3.4.2-CAPI-1.8.2 r3921"
 PROJ="Rel. 4.8.0, 6 March 2012" GDAL="GDAL 1.10.1, released 2013/08/26"
 LIBXML="2.9.1" LIBJSON="0.11.99" RASTER
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3990>
