[postgis-tickets] r16298 - with_interrupt_tests using non-standard extension
Regina Obe lr at pcorp.us
Sun Jan 14 04:24:58 PST 2018
Author: robe
Date: 2018-01-14 16:24:58 -0800 (Sun, 14 Jan 2018)
New Revision: 16298
   branches/2.4/NEWS
   branches/2.4/configure.ac
   branches/2.4/doc/release_notes.xml
Closes #3988 for PostGIS 2.4.3
Modified: branches/2.4/NEWS
--- branches/2.4/NEWS	2018-01-15 00:16:46 UTC (rev 16297)
+++ branches/2.4/NEWS	2018-01-15 00:24:58 UTC (rev 16298)
@@ -4,7 +4,8 @@
  * Bug fixes *
   - #3713, Support encodings that happen to output a '\' character
   - #3827, Set configure default to not do interrupt testing,
-           was causing false negatives for many people
+           was causing false negatives for many people (Regina Obe)
+           revised to be standards compliant in #3988 (Greg Troxel)
   - #3930, Minimum bounding circle issues on 32-bit platforms
   - #3965, ST_ClusterKMeans used to lose some clusters on initialization
            (Darafei Praliaskouski)
Modified: branches/2.4/configure.ac
--- branches/2.4/configure.ac	2018-01-15 00:16:46 UTC (rev 16297)
+++ branches/2.4/configure.ac	2018-01-15 00:24:58 UTC (rev 16298)
@@ -1191,7 +1191,7 @@
                     [Enable interrupt tests])],
     [INTERRUPTTESTS="yes"], [])
-if test "x$with_interrupt_tests" == "xno"; then
+if test "x$with_interrupt_tests" = "xno"; then
     INTERRUPTTESTS="no"
 fi
Modified: branches/2.4/doc/release_notes.xml
--- branches/2.4/doc/release_notes.xml	2018-01-15 00:16:46 UTC (rev 16297)
+++ branches/2.4/doc/release_notes.xml	2018-01-15 00:24:58 UTC (rev 16298)
@@ -11,7 +11,8 @@
         <title>Bug Fixes and Enhancements</title>
         <para>#3713, Support encodings that happen to output a '\' character</para>
         <para>#3827, Set configure default to not do interrupt testing,
-                  was causing false negatives for many people</para>
+                  was causing false negatives for many people. (Regina Obe)
+                 revised to be standards compliant in #3988 (Greg Troxel)</para>
         <para>#3930, Minimum bounding circle issues on 32-bit platforms</para>
         <para>#3965, ST_ClusterKMeans used to lose some clusters on initialization
                   (Darafei Praliaskouski)</para>
