[postgis-tickets] r16301 - more clearifying notes on HOWTO_RELEASE
Regina Obe
lr at pcorp.us
Mon Jan 15 12:47:31 PST 2018
Author: robe
Date: 2018-01-15 12:47:31 -0800 (Mon, 15 Jan 2018)
New Revision: 16301
branches/2.4/HOWTO_RELEASE
branches/2.4/Version.config
change version to 2.4.3 in prep for tagging tomorrow or Wednesday.
Modified: branches/2.4/HOWTO_RELEASE
--- branches/2.4/HOWTO_RELEASE 2018-01-15 02:19:08 UTC (rev 16300)
+++ branches/2.4/HOWTO_RELEASE 2018-01-15 20:47:31 UTC (rev 16301)
@@ -77,7 +77,6 @@
a) Replace PostGIS_* string params with new version
b) Replace repository url with new branch repo url
c) Update the PostGIS_trunk by updating the PostGIS_* string params
- d) create a new tagged branch job from latest tagged (and repeat a, b for this new tagged)
Go to: https://trac.osgeo.org/postgis/ edit the matrix to reflect new branch
@@ -87,8 +86,10 @@
$ rev=x.x.x
$ svn copy -m "Tagged release $rev" $base/branches/$brev $base/tags/$rev
- Run: sh make_dist.sh $rev (note, debbie should have already done this,
- and the file will be waiting in postgis.net/stuff)
+ and the file will be waiting in postgis.net/stuff. You might need to wait a few minutes to see it.)
+ If impatient check status of job - https://debbie.postgis.net/job/PostGIS_Make_Dist/
- Documentation should also have been built and should be in postgis.net/stuff
+ (this sometimes takes sometime so wait 15 minutes)
- Test generated tarball (including extension upgrade)
- Copy tarball, pdf, doc-html.. to http://download.osgeo.org/postgis/ web site and edit postgis.net/source page
- Announce on e-mail
Modified: branches/2.4/Version.config
--- branches/2.4/Version.config 2018-01-15 02:19:08 UTC (rev 16300)
+++ branches/2.4/Version.config 2018-01-15 20:47:31 UTC (rev 16301)
@@ -5,7 +5,7 @@
POSTGIS_MAJOR_VERSION=2
POSTGIS_MINOR_VERSION=4
-POSTGIS_MICRO_VERSION=3rc2
+POSTGIS_MICRO_VERSION=3
# Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
# when changing POSTGIS_MINOR_VERSION
