[postgis-tickets] r16308 - try again
Regina Obe
lr at pcorp.us
Mon Jan 15 02:17:45 PST 2018
Author: robe
Date: 2018-01-15 14:17:44 -0800 (Mon, 15 Jan 2018)
New Revision: 16308
trunk/ci/debbie/postgis_release_docs.sh
try again
Modified: trunk/ci/debbie/postgis_release_docs.sh
--- trunk/ci/debbie/postgis_release_docs.sh 2018-01-15 22:13:42 UTC (rev 16307)
+++ trunk/ci/debbie/postgis_release_docs.sh 2018-01-15 22:17:44 UTC (rev 16308)
@@ -44,7 +44,7 @@
#sed -e "s:</title>:</title><subtitle><subscript>SVN Revision (<emphasis>${POSTGIS_SVN_REVISION}</emphasis>)</subscript></subtitle>:" postgis.xml.orig > postgis.xml
#inject a development time stamp if we are in development branch
-if [[ "${POSTGIS_MICRO_VERSION}" == *dev* ]] ; then
+if [ "${POSTGIS_MICRO_VERSION}" == *dev* ] ; then
export GIT_TIMESTAMP=`git log -1 --pretty=format:%ct`
sed -e "s:</title>:</title><subtitle><subscript>DEV TIMESTAMP (<emphasis>${GIT_TIMESTAMP}</emphasis>)</subscript></subtitle>:" postgis.xml.orig > postgis.xml
fi
@@ -56,7 +56,7 @@
make epub
make -e chunked-html 2>&1 | tee -a doc-errors.log
-if [[ "$reference" == *trunk* ]] ; then #only do this for trunk because only trunk follows transifex
+if [ "$reference" == *trunk* ] ; then #only do this for trunk because only trunk follows transifex
make update-po
make -C po/it_IT/ local-html
make -C po/pt_BR/ local-html
