[postgis-tickets] [PostGIS] #3992: Use PKG_PROG_PKG_CONFIG macro from pkg.m4 to detect pkg-config.
trac at osgeo.org
Tue Jan 16 06:19:50 PST 2018
Reporter: Bas Couwenberg | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.4.3
Component: build/upgrade/install | Version: 2.4.x
Keywords: |
The `AC_PATH_PROG` macro fails to select the correct version to support
cross-compilation.
This triggers a lintian issue for the Debian package builds:
[https://lintian.debian.org/tags/autotools-pkg-config-macro-not-cross-
compilation-safe.html autotools-pkg-config-macro-not-cross-compilation-
safe]
> The package appears to use `AC_PATH_PROG` to discover the location of
`pkg-config(1)`. This macro fails to select the correct version to support
cross-compilation.
> A better way would be to use the `PKG_PROG_PKG_CONFIG` macro from
`pkg.m4` and then using the `$PKG_CONFIG` shell variable.
> Refer to https://bugs.debian.org/884798 for details.
The attached patch implements this suggestion.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3992>
