[postgis-tickets] r16320 - Backport support for Pg11 to 2.4 branch. Closes #3946
Paul Ramsey pramsey at cleverelephant.ca
Tue Jan 16 06:46:56 PST 2018
Author: pramsey
Date: 2018-01-16 06:46:55 -0800 (Tue, 16 Jan 2018)
New Revision: 16320
   branches/2.4/libpgcommon/lwgeom_pg.h
   branches/2.4/libpgcommon/lwgeom_transform.c
   branches/2.4/postgis/lwgeom_geos_prepared.c
Modified: branches/2.4/libpgcommon/lwgeom_pg.h
--- branches/2.4/libpgcommon/lwgeom_pg.h	2018-01-16 14:21:44 UTC (rev 16319)
+++ branches/2.4/libpgcommon/lwgeom_pg.h	2018-01-16 14:46:55 UTC (rev 16320)
@@ -144,6 +144,13 @@
 	#define STATRELATT STATRELATTINH
 #endif
+#if POSTGIS_PGSQL_VERSION >= 110
+#ifndef FALSE
+#define FALSE 0
+#define TRUE 1
+#endif
+#endif
 /* PG-exposed */
 Datum BOX2D_same(PG_FUNCTION_ARGS);
 Datum BOX2D_overlap(PG_FUNCTION_ARGS);
Modified: branches/2.4/libpgcommon/lwgeom_transform.c
--- branches/2.4/libpgcommon/lwgeom_transform.c	2018-01-16 14:21:44 UTC (rev 16319)
+++ branches/2.4/libpgcommon/lwgeom_transform.c	2018-01-16 14:46:55 UTC (rev 16320)
@@ -96,63 +96,25 @@
 static bool IsPROJ4LibPathSet = false;
 void SetPROJ4LibPath(void);
-/* Memory context cache functions */
-static void PROJ4SRSCacheInit(MemoryContext context);
-static void PROJ4SRSCacheDelete(MemoryContext context);
-static void PROJ4SRSCacheReset(MemoryContext context);
-static bool PROJ4SRSCacheIsEmpty(MemoryContext context);
-#if POSTGIS_PGSQL_VERSION >= 96
-static void PROJ4SRSCacheStats(MemoryContext context, int level, bool print, MemoryContextCounters *totals);
+static void
+#if POSTGIS_PGSQL_VERSION < 110
+PROJ4SRSCacheDelete(MemoryContext context)
 #else
-static void PROJ4SRSCacheStats(MemoryContext context, int level);
-#endif
-#ifdef MEMORY_CONTEXT_CHECKING
-static void PROJ4SRSCacheCheck(MemoryContext context);
-#endif
-/* Memory context definition must match the current version of PostgreSQL */
-static MemoryContextMethods PROJ4SRSCacheContextMethods =
+PROJ4SRSCacheDelete(void *ptr)
-	NULL,
-	NULL,
-	NULL,
-	PROJ4SRSCacheInit,
-	PROJ4SRSCacheReset,
-	PROJ4SRSCacheDelete,
-	NULL,
-	PROJ4SRSCacheIsEmpty,
-	PROJ4SRSCacheStats
-	,PROJ4SRSCacheCheck
+	MemoryContext context = (MemoryContext)ptr;
 #endif
-static void
-PROJ4SRSCacheInit(MemoryContext context)
-	 * Do nothing as the cache is initialised when the transform()
-	 * function is first called
-static void
-PROJ4SRSCacheDelete(MemoryContext context)
 	projPJ projection;
 	/* Lookup the projPJ pointer in the global hash table so we can free it */
 	projection = GetPJHashEntry(context);
 	if (!projection)
-		elog(ERROR, "PROJ4SRSCacheDelete: Trying to delete non-existant projection object with MemoryContext key (%p)", (void *)context);
+		elog(ERROR, "%s: Trying to delete non-existant projection object with MemoryContext key (%p)", __func__, (void *)context);
 	POSTGIS_DEBUGF(3, "deleting projection object (%p) with MemoryContext key (%p)", projection, context);
 	/* Free it */
 	pj_free(projection);
@@ -160,7 +122,18 @@
 	DeletePJHashEntry(context);
 static void
+PROJ4SRSCacheInit(MemoryContext context)
+	 * Do nothing as the cache is initialised when the transform()
+	 * function is first called
+static void
@@ -176,7 +149,7 @@
 	 * Always return false since this call is mandatory according to tgl
 	 * (see postgis-devel archives July 2007)
-	return FALSE;
+	return false;
 static void
@@ -203,9 +176,28 @@
 	 * with MEMORY_CONTEXT_CHECKING defined
+#endif /* MEMORY_CONTEXT_CHECKING */
+/* Memory context definition must match the current version of PostgreSQL */
+static MemoryContextMethods PROJ4SRSCacheContextMethods =
+	NULL,
+	NULL,
+	NULL,
+	PROJ4SRSCacheInit,
+	PROJ4SRSCacheReset,
+	PROJ4SRSCacheDelete,
+	NULL,
+	PROJ4SRSCacheIsEmpty,
+	PROJ4SRSCacheStats
+#ifdef MEMORY_CONTEXT_CHECKING
+	,PROJ4SRSCacheCheck
 #endif
+#endif /* POSTGIS_PGSQL_VERSION < 110 */
  * PROJ4 projPJ Hash Table functions
@@ -572,11 +564,25 @@
 	POSTGIS_DEBUGF(3, "adding SRID %d with proj4text \"%s\" to query cache at index %d", srid, proj_str, PROJ4Cache->PROJ4SRSCacheCount);
 	PJMemoryContext = MemoryContextCreate(T_AllocSetContext, 8192,
 	                                      &PROJ4SRSCacheContextMethods,
 	                                      PROJ4Cache->PROJ4SRSCacheContext,
 	                                      "PostGIS PROJ4 PJ Memory Context");
+#else
+	PJMemoryContext = AllocSetContextCreate(PROJ4Cache->PROJ4SRSCacheContext,
+	                                        "PostGIS PROJ4 PJ Memory Context",
+	                                        ALLOCSET_SMALL_SIZES);
+	/* PgSQL comments suggest allocating callback in the context */
+	/* being managed, so that the callback object gets cleaned along with */
+	/* the context */
+	MemoryContextCallback *callback = MemoryContextAlloc(PJMemoryContext, sizeof(MemoryContextCallback));
+	callback->arg = (void*)PJMemoryContext;
+	callback->func = PROJ4SRSCacheDelete;
+	MemoryContextRegisterResetCallback(PJMemoryContext, callback);
+#endif
 	/* Create the backend hash if it doesn't already exist */
 	if (!PJHash)
 		PJHash = CreatePJHash();
Modified: branches/2.4/postgis/lwgeom_geos_prepared.c
--- branches/2.4/postgis/lwgeom_geos_prepared.c	2018-01-16 14:21:44 UTC (rev 16319)
+++ branches/2.4/postgis/lwgeom_geos_prepared.c	2018-01-16 14:46:55 UTC (rev 16320)
@@ -94,57 +94,24 @@
 static PrepGeomHashEntry *GetPrepGeomHashEntry(MemoryContext mcxt);
 static void DeletePrepGeomHashEntry(MemoryContext mcxt);
-/* Memory context cache function prototypes */
-static void PreparedCacheInit(MemoryContext context);
-static void PreparedCacheReset(MemoryContext context);
-static void PreparedCacheDelete(MemoryContext context);
-static bool PreparedCacheIsEmpty(MemoryContext context);
-static void PreparedCacheStats(MemoryContext context, int level, bool print, MemoryContextCounters *totals);
-#else
-static void PreparedCacheStats(MemoryContext context, int level);
-#endif
-static void PreparedCacheCheck(MemoryContext context);
-#endif
-static MemoryContextMethods PreparedCacheContextMethods =
+static void
+PreparedCacheDelete(MemoryContext context)
-	NULL,
-	NULL,
-	NULL,
-	PreparedCacheInit,
-	PreparedCacheReset,
-	PreparedCacheDelete,
-	NULL,
-	PreparedCacheIsEmpty,
-	PreparedCacheStats
-	, PreparedCacheCheck
+#else
+PreparedCacheDelete(void *ptr)
 #endif
-static void
-PreparedCacheInit(MemoryContext context)
-static void
-PreparedCacheDelete(MemoryContext context)
 	PrepGeomHashEntry* pghe;
 	/* Lookup the hash entry pointer in the global hash table so we can free it */
 	pghe = GetPrepGeomHashEntry(context);
 	if (!pghe)
-		elog(ERROR, "PreparedCacheDelete: Trying to delete non-existant hash entry object with MemoryContext key (%p)", (void *)context);
+		elog(ERROR, "%s: Trying to delete non-existant hash entry object with MemoryContext key (%p)", __func__, (void *)context);
 	POSTGIS_DEBUGF(3, "deleting geom object (%p) and prepared geom object (%p) with MemoryContext key (%p)", pghe->geom, pghe->prepared_geom, context);
@@ -158,7 +125,18 @@
 	DeletePrepGeomHashEntry(context);
 static void
+PreparedCacheInit(MemoryContext context)
+static void
@@ -174,7 +152,7 @@
-	return FALSE;
+	return false;
 static void
@@ -201,8 +179,29 @@
+static MemoryContextMethods PreparedCacheContextMethods =
+	NULL,
+	NULL,
+	NULL,
+	PreparedCacheInit,
+	PreparedCacheReset,
+	PreparedCacheDelete,
+	NULL,
+	PreparedCacheIsEmpty,
+	PreparedCacheStats
+	, PreparedCacheCheck
 #endif
 /* TODO: put this in common are for both transform and prepared
 ** mcxt_ptr_hash
 ** Build a key from a pointer and a size value.
@@ -320,10 +319,25 @@
 	if ( ! prepcache->context_callback )
 		PrepGeomHashEntry pghe;
 		prepcache->context_callback = MemoryContextCreate(T_AllocSetContext, 8192,
 		                             &PreparedCacheContextMethods,
 		                             prepcache->context_statement,
 		                             "PostGIS Prepared Geometry Context");
+#else
+		prepcache->context_callback = AllocSetContextCreate(prepcache->context_statement,
+	                                   "PostGIS Prepared Geometry Context",
+		/* the context */
+		MemoryContextCallback *callback = MemoryContextAlloc(prepcache->context_callback, sizeof(MemoryContextCallback));
+		callback->arg = (void*)(prepcache->context_callback);
+		callback->func = PreparedCacheDelete;
+		MemoryContextRegisterResetCallback(prepcache->context_callback, callback);
+#endif
 		pghe.context = prepcache->context_callback;
 		pghe.geom = 0;
 		pghe.prepared_geom = 0;
