[postgis-tickets] r16322 - [travis] Enable -Wall
Darafei komzpa at gmail.com
Tue Jan 16 09:03:43 PST 2018
Author: komzpa
Date: 2018-01-16 09:03:43 -0800 (Tue, 16 Jan 2018)
New Revision: 16322
   trunk/.travis.yml
   trunk/postgis/gserialized_estimate.c
Closes https://github.com/postgis/postgis/pull/193
Modified: trunk/.travis.yml
--- trunk/.travis.yml	2018-01-16 14:47:33 UTC (rev 16321)
+++ trunk/.travis.yml	2018-01-16 17:03:43 UTC (rev 16322)
@@ -2,7 +2,7 @@
   matrix:
     - CFLAGS="-g -Og" MATRIX_EVAL="touch check-no-trailing-blanks"
     - CFLAGS="-g -O2 -fstack-protector -Wformat -Werror=format-security" LDFLAGS="-Wl,-Bsymbolic-functions -Wl,-z,relro"
-    - CFLAGS="-g -O3 -mtune=generic -fno-omit-frame-pointer -Werror"
+    - CFLAGS="-g -O3 -mtune=generic -fno-omit-frame-pointer -Werror -Wall"
     - CFLAGS="-g -O0 --coverage -fprofile-arcs -ftest-coverage" LDFLAGS="--coverage -fprofile-arcs -ftest-coverage" CONFIGURE_FLAGS="--enable-debug"
 addons:
Modified: trunk/postgis/gserialized_estimate.c
--- trunk/postgis/gserialized_estimate.c	2018-01-16 14:47:33 UTC (rev 16321)
+++ trunk/postgis/gserialized_estimate.c	2018-01-16 17:03:43 UTC (rev 16322)
@@ -1693,9 +1693,9 @@
 		int d;
 		double num_cells = 0;
 		double tmp_volume = 1.0;
-		double min[ND_DIMS];
-		double max[ND_DIMS];
-		double cellsize[ND_DIMS];
+		double min[ND_DIMS] = {0.0, 0.0, 0.0, 0.0};
+		double max[ND_DIMS] = {0.0, 0.0, 0.0, 0.0};
+		double cellsize[ND_DIMS] = {0.0, 0.0, 0.0, 0.0};
 		nd_box = sample_boxes[i];
 		if ( ! nd_box ) continue; /* Skip Null'ed out hard deviants */
