[postgis-tickets] [PostGIS] #3957: ST_StartPoint - not works correctly
PostGIS trac at osgeo.org
Tue Jan 16 10:44:22 PST 2018
  Reporter:  sanyasi  |      Owner:  pramsey
      Type:  defect   |     Status:  reopened
  Priority:  medium   |  Milestone:  PostGIS 2.4.4
 Component:  postgis  |    Version:  2.4.x
Resolution:           |   Keywords:
Comment (by pramsey):
 Can you write out, in SQL, a set of steps I can copy and paste into my
 terminal that will, when run on the different versions you indicate,
 output different results?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3957#comment:10>
