[postgis-tickets] r16333 - Fix sfcgal upgrade in run_test.pl
Sandro Santilli
strk at kbt.io
Thu Jan 18 01:41:32 PST 2018
Author: strk
Date: 2018-01-18 13:41:32 -0800 (Thu, 18 Jan 2018)
New Revision: 16333
trunk/regress/run_test.pl
Modified: trunk/regress/run_test.pl
--- trunk/regress/run_test.pl 2018-01-18 19:31:53 UTC (rev 16332)
+++ trunk/regress/run_test.pl 2018-01-18 21:41:32 UTC (rev 16333)
@@ -1475,15 +1475,16 @@
if ( $OPT_WITH_SFCGAL )
+ my $sql;
if ( semver_lessthan($OPT_UPGRADE_FROM, "2.2.0") )
print "NOTICE: installing SFCGAL extension on upgrade "
. "as it was not available in version $OPT_UPGRADE_FROM\n";
- my $sql = "CREATE EXTENSION postgis_sfcgal VERSION '${nextver}'";
+ $sql = "CREATE EXTENSION postgis_sfcgal VERSION '${nextver}'";
else
- my $sql = "ALTER EXTENSION postgis_sfcgal UPDATE TO '${nextver}'";
+ $sql = "ALTER EXTENSION postgis_sfcgal UPDATE TO '${nextver}'";
$cmd = "psql $psql_opts -c \"" . $sql . "\" $DB >> $REGRESS_LOG 2>&1";
$rv = system($cmd);
