[postgis-tickets] r16336 - Forgot to add pkg.m4 macro in r16324
Sandro Santilli
strk at kbt.io
Thu Jan 18 01:46:35 PST 2018
Author: strk
Date: 2018-01-18 13:46:35 -0800 (Thu, 18 Jan 2018)
New Revision: 16336
Added:
branches/2.4/macros/pkg.m4
See #3992
Added: branches/2.4/macros/pkg.m4
--- branches/2.4/macros/pkg.m4 (rev 0)
+++ branches/2.4/macros/pkg.m4 2018-01-18 21:46:35 UTC (rev 16336)
@@ -0,0 +1,275 @@
+dnl pkg.m4 - Macros to locate and utilise pkg-config. -*- Autoconf -*-
+dnl serial 11 (pkg-config-0.29)
+dnl
+dnl Copyright © 2004 Scott James Remnant <scott at netsplit.com>.
+dnl Copyright © 2012-2015 Dan Nicholson <dbn.lists at gmail.com>
+dnl
+dnl This program is free software; you can redistribute it and/or modify
+dnl it under the terms of the GNU General Public License as published by
+dnl the Free Software Foundation; either version 2 of the License, or
+dnl (at your option) any later version.
+dnl
+dnl This program is distributed in the hope that it will be useful, but
+dnl WITHOUT ANY WARRANTY; without even the implied warranty of
+dnl MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+dnl General Public License for more details.
+dnl
+dnl You should have received a copy of the GNU General Public License
+dnl along with this program; if not, write to the Free Software
+dnl Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA
+dnl 02111-1307, USA.
+dnl
+dnl As a special exception to the GNU General Public License, if you
+dnl distribute this file as part of a program that contains a
+dnl configuration script generated by Autoconf, you may include it under
+dnl the same distribution terms that you use for the rest of that
+dnl program.
+dnl PKG_PREREQ(MIN-VERSION)
+dnl -----------------------
+dnl Since: 0.29
+dnl
+dnl Verify that the version of the pkg-config macros are at least
+dnl MIN-VERSION. Unlike PKG_PROG_PKG_CONFIG, which checks the user's
+dnl installed version of pkg-config, this checks the developer's version
+dnl of pkg.m4 when generating configure.
+dnl
+dnl To ensure that this macro is defined, also add:
+dnl m4_ifndef([PKG_PREREQ],
+dnl [m4_fatal([must install pkg-config 0.29 or later before running autoconf/autogen])])
+dnl
+dnl See the "Since" comment for each macro you use to see what version
+dnl of the macros you require.
+m4_defun([PKG_PREREQ],
+[m4_define([PKG_MACROS_VERSION], [0.29])
+m4_if(m4_version_compare(PKG_MACROS_VERSION, [$1]), -1,
+ [m4_fatal([pkg.m4 version $1 or higher is required but ]PKG_MACROS_VERSION[ found])])
+])dnl PKG_PREREQ
+dnl PKG_PROG_PKG_CONFIG([MIN-VERSION])
+dnl ----------------------------------
+dnl Since: 0.16
+dnl
+dnl Search for the pkg-config tool and set the PKG_CONFIG variable to
+dnl first found in the path. Checks that the version of pkg-config found
+dnl is at least MIN-VERSION. If MIN-VERSION is not specified, 0.9.0 is
+dnl used since that's the first version where most current features of
+dnl pkg-config existed.
+AC_DEFUN([PKG_PROG_PKG_CONFIG],
+[m4_pattern_forbid([^_?PKG_[A-Z_]+$])
+m4_pattern_allow([^PKG_CONFIG(_(PATH|LIBDIR|SYSROOT_DIR|ALLOW_SYSTEM_(CFLAGS|LIBS)))?$])
+m4_pattern_allow([^PKG_CONFIG_(DISABLE_UNINSTALLED|TOP_BUILD_DIR|DEBUG_SPEW)$])
+AC_ARG_VAR([PKG_CONFIG], [path to pkg-config utility])
+AC_ARG_VAR([PKG_CONFIG_PATH], [directories to add to pkg-config's search path])
+AC_ARG_VAR([PKG_CONFIG_LIBDIR], [path overriding pkg-config's built-in search path])
+if test "x$ac_cv_env_PKG_CONFIG_set" != "xset"; then
+ AC_PATH_TOOL([PKG_CONFIG], [pkg-config])
+fi
+if test -n "$PKG_CONFIG"; then
+ _pkg_min_version=m4_default([$1], [0.9.0])
+ AC_MSG_CHECKING([pkg-config is at least version $_pkg_min_version])
+ if $PKG_CONFIG --atleast-pkgconfig-version $_pkg_min_version; then
+ AC_MSG_RESULT([yes])
+ else
+ AC_MSG_RESULT([no])
+ PKG_CONFIG=""
+ fi
+fi[]dnl
+])dnl PKG_PROG_PKG_CONFIG
+dnl PKG_CHECK_EXISTS(MODULES, [ACTION-IF-FOUND], [ACTION-IF-NOT-FOUND])
+dnl -------------------------------------------------------------------
+dnl Since: 0.18
+dnl
+dnl Check to see whether a particular set of modules exists. Similar to
+dnl PKG_CHECK_MODULES(), but does not set variables or print errors.
+dnl
+dnl Please remember that m4 expands AC_REQUIRE([PKG_PROG_PKG_CONFIG])
+dnl only at the first occurence in configure.ac, so if the first place
+dnl it's called might be skipped (such as if it is within an "if", you
+dnl have to call PKG_CHECK_EXISTS manually
+AC_DEFUN([PKG_CHECK_EXISTS],
+[AC_REQUIRE([PKG_PROG_PKG_CONFIG])dnl
+if test -n "$PKG_CONFIG" && \
+ AC_RUN_LOG([$PKG_CONFIG --exists --print-errors "$1"]); then
+ m4_default([$2], [:])
+m4_ifvaln([$3], [else
+ $3])dnl
+fi])
+dnl _PKG_CONFIG([VARIABLE], [COMMAND], [MODULES])
+dnl Internal wrapper calling pkg-config via PKG_CONFIG and setting
+dnl pkg_failed based on the result.
+m4_define([_PKG_CONFIG],
+[if test -n "$$1"; then
+ pkg_cv_[]$1="$$1"
+ elif test -n "$PKG_CONFIG"; then
+ PKG_CHECK_EXISTS([$3],
+ [pkg_cv_[]$1=`$PKG_CONFIG --[]$2 "$3" 2>/dev/null`
+ test "x$?" != "x0" && pkg_failed=yes ],
+ [pkg_failed=yes])
+ else
+ pkg_failed=untried
+fi[]dnl
+])dnl _PKG_CONFIG
+dnl _PKG_SHORT_ERRORS_SUPPORTED
+dnl Internal check to see if pkg-config supports short errors.
+AC_DEFUN([_PKG_SHORT_ERRORS_SUPPORTED],
+if $PKG_CONFIG --atleast-pkgconfig-version 0.20; then
+ _pkg_short_errors_supported=yes
+else
+ _pkg_short_errors_supported=no
+fi[]dnl
+])dnl _PKG_SHORT_ERRORS_SUPPORTED
+dnl PKG_CHECK_MODULES(VARIABLE-PREFIX, MODULES, [ACTION-IF-FOUND],
+dnl [ACTION-IF-NOT-FOUND])
+dnl Since: 0.4.0
+dnl
+dnl Note that if there is a possibility the first call to
+dnl PKG_CHECK_MODULES might not happen, you should be sure to include an
+dnl explicit call to PKG_PROG_PKG_CONFIG in your configure.ac
+AC_DEFUN([PKG_CHECK_MODULES],
+AC_ARG_VAR([$1][_CFLAGS], [C compiler flags for $1, overriding pkg-config])dnl
+AC_ARG_VAR([$1][_LIBS], [linker flags for $1, overriding pkg-config])dnl
+pkg_failed=no
+AC_MSG_CHECKING([for $1])
+_PKG_CONFIG([$1][_CFLAGS], [cflags], [$2])
+_PKG_CONFIG([$1][_LIBS], [libs], [$2])
+m4_define([_PKG_TEXT], [Alternatively, you may set the environment variables $1[]_CFLAGS
+and $1[]_LIBS to avoid the need to call pkg-config.
+See the pkg-config man page for more details.])
+if test $pkg_failed = yes; then
+ _PKG_SHORT_ERRORS_SUPPORTED
+ if test $_pkg_short_errors_supported = yes; then
+ $1[]_PKG_ERRORS=`$PKG_CONFIG --short-errors --print-errors --cflags --libs "$2" 2>&1`
+ else
+ $1[]_PKG_ERRORS=`$PKG_CONFIG --print-errors --cflags --libs "$2" 2>&1`
+ fi
+ # Put the nasty error message in config.log where it belongs
+ echo "$$1[]_PKG_ERRORS" >&AS_MESSAGE_LOG_FD
+ m4_default([$4], [AC_MSG_ERROR(
+[Package requirements ($2) were not met:
+$$1_PKG_ERRORS
+Consider adjusting the PKG_CONFIG_PATH environment variable if you
+installed software in a non-standard prefix.
+_PKG_TEXT])[]dnl
+elif test $pkg_failed = untried; then
+ m4_default([$4], [AC_MSG_FAILURE(
+[The pkg-config script could not be found or is too old. Make sure it
+is in your PATH or set the PKG_CONFIG environment variable to the full
+path to pkg-config.
+_PKG_TEXT
+To get pkg-config, see <http://pkg-config.freedesktop.org/>.])[]dnl
+else
+ $1[]_CFLAGS=$pkg_cv_[]$1[]_CFLAGS
+ $1[]_LIBS=$pkg_cv_[]$1[]_LIBS
+ $3
+fi[]dnl
+])dnl PKG_CHECK_MODULES
+dnl PKG_CHECK_MODULES_STATIC(VARIABLE-PREFIX, MODULES, [ACTION-IF-FOUND],
+dnl ---------------------------------------------------------------------
+dnl Since: 0.29
+dnl
+dnl Checks for existence of MODULES and gathers its build flags with
+dnl static libraries enabled. Sets VARIABLE-PREFIX_CFLAGS from --cflags
+dnl and VARIABLE-PREFIX_LIBS from --libs.
+dnl
+dnl PKG_CHECK_MODULES_STATIC might not happen, you should be sure to
+dnl include an explicit call to PKG_PROG_PKG_CONFIG in your
+dnl configure.ac.
+AC_DEFUN([PKG_CHECK_MODULES_STATIC],
+_save_PKG_CONFIG=$PKG_CONFIG
+PKG_CONFIG="$PKG_CONFIG --static"
+PKG_CHECK_MODULES($@)
+PKG_CONFIG=$_save_PKG_CONFIG[]dnl
+])dnl PKG_CHECK_MODULES_STATIC
+dnl PKG_INSTALLDIR([DIRECTORY])
+dnl Since: 0.27
+dnl
+dnl Substitutes the variable pkgconfigdir as the location where a module
+dnl should install pkg-config .pc files. By default the directory is
+dnl $libdir/pkgconfig, but the default can be changed by passing
+dnl DIRECTORY. The user can override through the --with-pkgconfigdir
+dnl parameter.
+AC_DEFUN([PKG_INSTALLDIR],
+[m4_pushdef([pkg_default], [m4_default([$1], ['${libdir}/pkgconfig'])])
+m4_pushdef([pkg_description],
+ [pkg-config installation directory @<:@]pkg_default[@:>@])
+AC_ARG_WITH([pkgconfigdir],
+ [AS_HELP_STRING([--with-pkgconfigdir], pkg_description)],,
+ [with_pkgconfigdir=]pkg_default)
+AC_SUBST([pkgconfigdir], [$with_pkgconfigdir])
+m4_popdef([pkg_default])
+m4_popdef([pkg_description])
+])dnl PKG_INSTALLDIR
+dnl PKG_NOARCH_INSTALLDIR([DIRECTORY])
+dnl Since: 0.27
+dnl
+dnl Substitutes the variable noarch_pkgconfigdir as the location where a
+dnl module should install arch-independent pkg-config .pc files. By
+dnl default the directory is $datadir/pkgconfig, but the default can be
+dnl changed by passing DIRECTORY. The user can override through the
+dnl --with-noarch-pkgconfigdir parameter.
+AC_DEFUN([PKG_NOARCH_INSTALLDIR],
+[m4_pushdef([pkg_default], [m4_default([$1], ['${datadir}/pkgconfig'])])
+ [pkg-config arch-independent installation directory @<:@]pkg_default[@:>@])
+AC_ARG_WITH([noarch-pkgconfigdir],
+ [AS_HELP_STRING([--with-noarch-pkgconfigdir], pkg_description)],,
+ [with_noarch_pkgconfigdir=]pkg_default)
+AC_SUBST([noarch_pkgconfigdir], [$with_noarch_pkgconfigdir])
+])dnl PKG_NOARCH_INSTALLDIR
+dnl PKG_CHECK_VAR(VARIABLE, MODULE, CONFIG-VARIABLE,
+dnl [ACTION-IF-FOUND], [ACTION-IF-NOT-FOUND])
+dnl Since: 0.28
+dnl
+dnl Retrieves the value of the pkg-config variable for the given module.
+AC_DEFUN([PKG_CHECK_VAR],
+AC_ARG_VAR([$1], [value of $3 for $2, overriding pkg-config])dnl
+_PKG_CONFIG([$1], [variable="][$3]["], [$2])
+AS_VAR_COPY([$1], [pkg_cv_][$1])
+AS_VAR_IF([$1], [""], [$5], [$4])dnl
+])dnl PKG_CHECK_VAR
