[postgis-tickets] [PostGIS] #3995: Build failures with unusual CC/CFLAGS setup
PostGIS trac at osgeo.org
Fri Jan 19 07:22:50 PST 2018
 Reporter:  Algunenano   |      Owner:  pramsey
     Type:  enhancement  |     Status:  new
 Priority:  medium       |  Milestone:  PostGIS 2.5.0
Component:  postgis      |    Version:  trunk
 Keywords:               |
 I've been trying to run both postgres and postgis fully under the
 sanitizers but in some steps it is using the default compiler or flags
 instead of the ones passed during configuration, which makes the build
 fail.
 PR in Github: https://github.com/postgis/postgis/pull/195
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3995>
