[postgis-tickets] [PostGIS] #3996: https://www.postgis.net has invalid SSL certificate
trac at osgeo.org
Fri Jan 19 08:24:55 PST 2018
Reporter: strk | Owner: robe
Type: defect | Status: assigned
Priority: medium | Milestone: Management 2.0
Component: postgis | Version: 2.4.x
Keywords: |
www.postgis.net uses an invalid security certificate. The certificate is
only valid for postgis.net Error code: SSL_ERROR_BAD_CERT_DOMAIN
it takes another letsencrypt run to deal with that, and two separate SSL
configurations for the two VirtualHost...
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3996>
