[postgis-tickets] [PostGIS] #4000: unpackaged--2.5.0dev upgrade test fails due to postgis.backend being redefined
trac at osgeo.org
Fri Jan 19 23:17:42 PST 2018
redefined
Reporter: strk | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.5.0
Component: postgis | Version: trunk
Keywords: |
cd regress
./run_test.pl -v --sfcgal --upgrade --extension --upgrade-path
unpackaged--
2.5.0dev regress_sfcgal.sql
Upgrade path: unpackaged --> 2.5.0dev
PATH is
/home/strk/perl5/bin:/home/strk/perl5/bin:/home/strk/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/usr/lib/go-1.8/bin:/home/strk/bin:/home/strk/go/bin:/home/strk/bin:/home/strk/go/bin
Checking for shp2pgsql ... found
Checking for pgsql2shp ... found
Checking for raster2pgsql ... found
TMPDIR is /tmp/pgis_reg
Creating database 'postgis_reg'
Loading PostGIS into 'postgis_reg'
/usr/src/postgis/repository-sync-scripts/postgis/regress/00-regress-
install/share/contrib/postgis/postgis.sql
install/share/contrib/postgis/postgis_comments.sql
install/share/contrib/postgis/postgis_proc_set_search_path.sql
Loading Raster into 'postgis_reg'
install/share/contrib/postgis/rtpostgis.sql
install/share/contrib/postgis/raster_comments.sql
install/share/contrib/postgis/rtpostgis_proc_set_search_path.sql
Loading SFCGAL into 'postgis_reg'
install/share/contrib/postgis/sfcgal.sql
install/share/contrib/postgis/sfcgal_comments.sql
Upgrading PostGIS in 'postgis_reg' using: CREATE EXTENSION postgis VERSION
'2.5.0dev' FROM unpackaged
Upgrading PostGIS SFCGAL in 'postgis_reg' using: CREATE EXTENSION
postgis_sfcgal VERSION '2.5.0dev' FROM unpackaged
PostgreSQL 9.6.6 on x86_64-pc-linux-gnu, compiled by gcc (Ubuntu
6.3.0-12ubuntu2) 6.3.0 20170406, 64-bit
Postgis 2.5.0dev - r16335 - 2018-01-18 21:56:50
scripts 2.5.0dev r16335
raster scripts 2.5.0dev r16335
GEOS: 3.7.0dev-CAPI-1.11.0 c60c5e3d
PROJ: Rel. 4.9.3, 15 August 2016
SFCGAL: 1.3.0
GDAL: GDAL 2.3.0dev, released 2017/99/99
Running tests
regress_sfcgal .. failed (diff expected obtained:
/tmp/pgis_reg/test_1_diff)
--- regress_sfcgal_expected 2018-01-18 11:03:16.489351339 +0100
+++ /tmp/pgis_reg/test_1_out 2018-01-20 08:15:48.911376245 +0100
@@ -1,4 +1,5 @@
postgis_sfcgal_version|1
+WARNING: 'postgis.backend' is already set and cannot be changed until
you reconnect
ST_Tesselate|GEOMETRYCOLLECTION(POINT(4 4),TIN(((0 1,1 0,1 1,0 1)),((0
1,0 0,1 0,0 1))))
ST_3DArea|1
ST_Extrude_point|LINESTRING Z (0 0 0,1 0 0)
uninstall .. ok (4581)
Run tests: 2
Failed: 1
The bug is also exposed by Debbie:
https://debbie.postgis.net/job/PostGIS_Regress/8456/console
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4000>
