[postgis-tickets] r16347 - change scripts back to versions of things to compile against (GDAL, PROJ, SCGAL, GEOS) being set at job level until we have the stop and start postgres in repo as well.
Regina Obe lr at pcorp.us
Sat Jan 20 11:12:17 PST 2018
Author: robe
Date: 2018-01-20 23:12:17 -0800 (Sat, 20 Jan 2018)
New Revision: 16347
   branches/2.4/ci/winnie/build_postgis.sh
   branches/2.4/ci/winnie/package_postgis.sh
   branches/2.4/ci/winnie/regress_postgis.sh
Modified: branches/2.4/ci/winnie/build_postgis.sh
--- branches/2.4/ci/winnie/build_postgis.sh	2018-01-20 12:58:39 UTC (rev 16346)
+++ branches/2.4/ci/winnie/build_postgis.sh	2018-01-21 07:12:17 UTC (rev 16347)
@@ -8,15 +8,15 @@
 #export PGPORT=8442
 #POSTGIS_SVN_REVISION=passed_in_by_buildbot
-export GEOS_VER=3.7.0dev
-export GDAL_VER=2.2.2
-export PROJ_VER=4.9.3
-export SFCGAL_VER=1.3
-export PCRE_VER=8.33
-export PROTOBUF_VER=3.2.0
-export PROTOBUFC_VER=1.2.1
+# export GEOS_VER=3.7.0dev
+# export GDAL_VER=2.2.3
+# export PROJ_VER=4.9.3
+# export SFCGAL_VER=1.3.2
+# export PCRE_VER=8.33
+# export PROTOBUF_VER=3.2.0
+# export PROTOBUFC_VER=1.2.1
 export LIBXML_VER=2.7.8
 if [[ "${GCC_TYPE}" == *gcc48* ]] ; then
@@ -95,7 +95,7 @@
 if [ -n "$SFCGAL_VER" ]; then
 	##hard code versions of cgal etc. for now
-	export CGAL_VER=4.6.1
+	export CGAL_VER=4.11
 	BOOST_VER=1.53.0
 	#BOOST_VER_WU=1_49_0
 	export BOOST_VER_WU=1_53_0
Modified: branches/2.4/ci/winnie/package_postgis.sh
--- branches/2.4/ci/winnie/package_postgis.sh	2018-01-20 12:58:39 UTC (rev 16346)
+++ branches/2.4/ci/winnie/package_postgis.sh	2018-01-21 07:12:17 UTC (rev 16347)
@@ -9,18 +9,18 @@
 #POSTGIS_MAJOR_VERSION=2
 #POSTGIS_MINOR_VERSION=1
 #POSTGIS_MICRO_VERSION=0dev
-export GEOS_VER=3.6.2
+# export GEOS_VER=3.6.2
+# export GDAL_VER=2.2.2
-export LIBXML_VER=2.7.8
+# export LIBXML_VER=2.7.8
 	export PROJECTS=/projects
Modified: branches/2.4/ci/winnie/regress_postgis.sh
--- branches/2.4/ci/winnie/regress_postgis.sh	2018-01-20 12:58:39 UTC (rev 16346)
+++ branches/2.4/ci/winnie/regress_postgis.sh	2018-01-21 07:12:17 UTC (rev 16347)
@@ -7,21 +7,21 @@
 #export POSTGIS_MAJOR_VERSION=2
 #export POSTGIS_MINOR_VERSION=2
 #export POSTGIS_MICRO_VERSION=0dev
 export MINGPROJECTS=/projects
 export PATHOLD=$PATH
 export MAKE_EXTENSION=1
