[postgis-tickets] r16352 - Backport run_test.pl fixes from trunk
Sandro Santilli
strk at kbt.io
Mon Jan 22 03:33:27 PST 2018
Author: strk
Date: 2018-01-22 03:33:27 -0800 (Mon, 22 Jan 2018)
New Revision: 16352
branches/2.2/regress/run_test.pl
Modified: branches/2.2/regress/run_test.pl
--- branches/2.2/regress/run_test.pl 2018-01-22 11:31:37 UTC (rev 16351)
+++ branches/2.2/regress/run_test.pl 2018-01-22 11:33:27 UTC (rev 16352)
@@ -4,7 +4,7 @@
# PostGIS - Spatial Types for PostgreSQL
# http://postgis.net
-# Copyright (C) 2012-2014 Sandro Santilli <strk at keybit.net>
+# Copyright (C) 2012-2018 Sandro Santilli <strk at kbt.io>
# Copyright (C) 2014-2015 Regina Obe <lr at pcorp.us>
# Copyright (C) 2012-2013 Paul Ramsey <pramsey at cleverelephant.ca>
@@ -67,7 +67,7 @@
my $OPT_EXTENSIONS = 0;
my $OPT_EXTVERSION = '';
my $OPT_UPGRADE_PATH = '';
-my $OPT_UPGRADE_FROM = '';
+our $OPT_UPGRADE_FROM = '';
my $OPT_UPGRADE_TO = '';
my $VERBOSE = 0;
@@ -205,7 +205,7 @@
$TMPDIR = tempdir( CLEANUP => 0 );
-mkdir $TMPDIR if ( ! -d $TMPDIR );
+mkpath $TMPDIR; # make sure tmp dir exists
# Set log name
my $REGRESS_LOG = "${TMPDIR}/regress_log";
@@ -258,6 +258,21 @@
exit(1);
+sub semver_lessthan
+ my ($a,$b) = @_;
+ my @acomp = split(/\./, $a);
+ my @bcomp = split(/\./, $b);
+ foreach my $ac (@acomp) {
+ my $bc = shift(@bcomp);
+ return 0 if not defined($bc); # $b has less components
+ return 1 if ( $ac < $bc ); # $a is less than $b
+ return 0 if ( $ac > $bc ); # $a is not less than $b
+ # $a is equal to $b so far, if $b has more elements,
+ # it is bigger
+ return @bcomp ? 1 : 0;
sub create_upgrade_test_objects
@@ -430,7 +445,8 @@
print " skipped (can't read any ${TEST}.{sql,dbf,tif,dmp})\n";
$SKIP++;
- next;
+ # Even though we skipped this test, we will still run the cleanup
+ # scripts
if ( -r "${TEST}-post.sql" )
@@ -1290,6 +1306,9 @@
if ( $OPT_UPGRADE_FROM ) {
$sql .= " VERSION '" . $OPT_UPGRADE_FROM . "'";
+ print "Preparing db '${DB}' using: ${sql}\n";
$cmd = "psql $psql_opts -c \"" . $sql . "\" $DB >> $REGRESS_LOG 2>&1";
$rv = system($cmd);
if ( $rv ) {
@@ -1300,16 +1319,27 @@
if ( $OPT_WITH_SFCGAL )
- my $sql = "CREATE EXTENSION postgis_sfcgal";
- if ( $OPT_UPGRADE_FROM ) {
- $sql .= " VERSION '" . $OPT_UPGRADE_FROM . "'";
- $cmd = "psql $psql_opts -c \"" . $sql . "\" $DB >> $REGRESS_LOG 2>&1";
- $rv = system($cmd);
- if ( $rv ) {
- fail "Error encountered creating EXTENSION POSTGIS_SFCGAL", $REGRESS_LOG;
- die;
+ do {
+ my $sql = "CREATE EXTENSION postgis_sfcgal";
+ if ( $OPT_UPGRADE_FROM ) {
+ if ( semver_lessthan($OPT_UPGRADE_FROM, "2.2.0") )
+ print "NOTICE: skipping SFCGAL extension create "
+ . "as not available in version '$OPT_UPGRADE_FROM'\n";
+ last;
+ $sql .= " VERSION '" . $OPT_UPGRADE_FROM . "'";
+ $cmd = "psql $psql_opts -c \"" . $sql . "\" $DB >> $REGRESS_LOG 2>&1";
+ $rv = system($cmd);
+ if ( $rv ) {
+ fail "Error encountered creating EXTENSION POSTGIS_SFCGAL", $REGRESS_LOG;
+ die;
+ } while (0);
return 1;
@@ -1323,6 +1353,7 @@
# Load postgis.sql into the database
load_sql_file("${STAGED_SCRIPTS_DIR}/postgis.sql", 1);
load_sql_file("${STAGED_SCRIPTS_DIR}/postgis_comments.sql", 0);
+ load_sql_file("${STAGED_SCRIPTS_DIR}/postgis_proc_set_search_path.sql", 0);
if ( $OPT_WITH_TOPO )
@@ -1336,6 +1367,7 @@
print "Loading Raster into '${DB}'\n";
load_sql_file("${STAGED_SCRIPTS_DIR}/rtpostgis.sql", 1);
load_sql_file("${STAGED_SCRIPTS_DIR}/raster_comments.sql", 0);
+ load_sql_file("${STAGED_SCRIPTS_DIR}/rtpostgis_proc_set_search_path.sql", 0);
@@ -1395,6 +1427,22 @@
die "$script not found\n";
+ if ( $OPT_WITH_SFCGAL )
+ my $script = `ls ${STAGED_SCRIPTS_DIR}/sfcgal_upgrade.sql`;
+ chomp($script);
+ if ( -e $script )
+ print "Upgrading sfcgal\n";
+ load_sql_file($script);
+ else
+ die "$script not found\n";
return 1;
@@ -1423,6 +1471,13 @@
my $sql = "ALTER EXTENSION postgis_topology UPDATE TO '${nextver}'";
+ if ( $OPT_UPGRADE_FROM eq "unpackaged" ) {
+ $sql = "CREATE EXTENSION postgis_topology VERSION '${nextver}' FROM unpackaged";
+ print "Upgrading PostGIS Topology in '${DB}' using: ${sql}\n" ;
my $cmd = "psql $psql_opts -c \"" . $sql . "\" $DB >> $REGRESS_LOG 2>&1";
my $rv = system($cmd);
if ( $rv ) {
@@ -1431,6 +1486,34 @@
+ my $sql;
+ $sql = "CREATE EXTENSION postgis_sfcgal VERSION '${nextver}' FROM unpackaged";
+ elsif ( $OPT_UPGRADE_FROM && semver_lessthan($OPT_UPGRADE_FROM, "2.2.0") )
+ print "NOTICE: installing SFCGAL extension on upgrade "
+ . "as it was not available in version '$OPT_UPGRADE_FROM'\n";
+ $sql = "CREATE EXTENSION postgis_sfcgal VERSION '${nextver}'";
+ else
+ $sql = "ALTER EXTENSION postgis_sfcgal UPDATE TO '${nextver}'";
+ print "Upgrading PostGIS SFCGAL in '${DB}' using: ${sql}\n" ;
+ if ( $rv ) {
+ die;
return 1;
@@ -1530,7 +1613,7 @@
print "Dumping and restoring database '${DB}'\n";
- $rv = system("pg_dump -Fc ${DB} -f ${DBDUMP} >> $REGRESS_LOG 2>&1");
+ $rv = system("pg_dump -Fc -f${DBDUMP} ${DB} >> $REGRESS_LOG 2>&1");
if ( $rv ) {
fail("Could not dump ${DB}", $REGRESS_LOG);
die;
