[postgis-tickets] [PostGIS] #4036: OOM when PostGIS installed with pg_store_plans
trac at osgeo.org
Mon Mar 5 06:42:14 PST 2018
Reporter: pramsey | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.4.4
Component: postgis | Version: 2.4.x
Resolution: invalid | Keywords:
Changes (by pramsey):
* status: assigned => closed
* resolution: => invalid
Comment:
The backtrace during the OOM event indicates that the problem is actually
in the pg_store_plans parser trying to handle the PostGIS extension
script, not in PostGIS itself. Unfortunately the whole extension script
seems to be fed into the pg_store_plans machinery, so it's well nigh
impossible on our part to find out which bit it objects to. This issue
should be sent to pg_store_plans, as "ability to handle whatever junk is
passed to you on input" is an important feature of any extension.
* frame #0: 0x000000010de38ef5 pg_store_plans.so`norm_yylex + 469
frame #1: 0x000000010de3863b pg_store_plans.so`normalize_expr + 107
frame #2: 0x000000010de37194 pg_store_plans.so`hash_query + 36
frame #3: 0x000000010de3636b pg_store_plans.so`pgsp_ExecutorEnd + 475
frame #4: 0x000000010ce64a77
postgres`ExecutorEnd(queryDesc=0x00007f8baa28f498) + 39 at execMain.c:464
frame #5: 0x000000010cdd26bc postgres`execute_sql_string(sql="\n-- - -
-\n--\n--\n-- PostGIS - Spatial Types for PostgreSQL\n--
http://postgis.net\n-- Copyright 2001-2003 Refractions Research
Inc.\n--\n-- This is free software; you can redistribute and/or modify it
under\n-- the terms of the GNU General Public Licence. See the COPYING
file.\n--\n-- - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -
- - - - -\n--\n-- WARNING: Any change in this file must be evaluated for
compatibility.\n-- Changes cleanly handled by postgis_upgrade.sql
are fine,\n--\t other changes will require a bump in Major
version.\n--\t Currently only function replaceble by CREATE OR
REPLACE\n--\t are cleanly handled.\n--\n-- - - - - - - - - - - - - - -
-\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n--
INSTALL VERSION: '2.5.0dev'\n\n\nSET LOCAL client_min_messages TO
warning;\n\n-- Check that no other postgis is installed\nDO $$\nDECLARE\n
rec RECORD;\nBEGIN\n FOR rec IN\n SELECT n.nspname, p.prona"...,
filename="/opt/pgsql/10/share/extension/postgis--2.5.0dev.sql") + 364 at
extension.c:752
frame #6: 0x000000010cdd1ac4
postgres`execute_extension_script(extensionOid=2255231,
control=0x00007f8bca008ef0, from_version=0x0000000000000000,
version="2.5.0dev", requiredSchemas=0x0000000000000000,
schemaName="public", schemaOid=2200) + 1380 at extension.c:924
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4036#comment:1>
