[postgis-tickets] r16445 - ST_OffsetCurve: update docs about MULTI*
Darafei
komzpa at gmail.com
Mon Mar 5 09:30:42 PST 2018
Author: komzpa
Date: 2018-03-05 09:30:42 -0800 (Mon, 05 Mar 2018)
New Revision: 16445
trunk/doc/reference_processing.xml
References #2508
Modified: trunk/doc/reference_processing.xml
--- trunk/doc/reference_processing.xml 2018-03-05 16:54:13 UTC (rev 16444)
+++ trunk/doc/reference_processing.xml 2018-03-05 17:30:42 UTC (rev 16445)
@@ -2496,6 +2496,11 @@
</para>
<para>
+Enhanced: 2.5 - added support for GEOMETRYCOLLECTION and MULTILINESTRING
+ </para>
+ <para>
The optional third parameter allows specifying a list of blank-separated
key=value pairs to tweak operations as follows:
<itemizedlist>
@@ -2515,8 +2520,6 @@
Units of distance are measured in units of the spatial reference system.
</para>
- <para>The inputs can only be LINESTRINGS.</para>
<para>Performed by the GEOS module.</para>
<note><para>
