[postgis-tickets] [PostGIS] #4042: rect tree test failure
trac at osgeo.org
Fri Mar 9 07:38:57 PST 2018
Reporter: dbaston | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.5.0
Component: postgis | Version: trunk
Keywords: |
I'm seeing a cunit test failure in trunk:
Suite: measures
Test: test_mindistance2d_tolerance ...passed
Test: test_rect_tree_contains_point ...passed
Test: test_rect_tree_intersects_tree ...FAILED
1. cu_measures.c:413 - CU_ASSERT_EQUAL(tree_inter( "POLYGON((0 0, 3
1, 0 2, 3 3, 0 4, 3 5, 0 6, 5 6, 5 0, 0 0))",
"GEOMETRYCOLLECTION(MULTILINESTRING((6 3, 8 4)),POINT(1 3.5))"),LW_FALSE)
Test: test_lwgeom_segmentize2d ...passed
Test: test_lwgeom_locate_along ...passed
Test: test_lw_dist2d_pt_arc ...passed
Test: test_lw_dist2d_seg_arc ...passed
Test: test_lw_dist2d_arc_arc ...passed
Test: test_lw_arc_length ...passed
Test: test_lw_dist2d_pt_ptarrayarc ...passed
Test: test_lw_dist2d_ptarray_ptarrayarc ...passed
Test: test_lwgeom_tcpa ...passed
Test: test_lwgeom_is_trajectory ...passed
Test: test_rect_tree_distance_tree ...NOTICE: liblwgeom code interrupted
NOTICE: Geometry is not a LINESTRING
NOTICE: Line does not have M dimension
NOTICE: Measure of vertex 1 (1) not bigger than measure of vertex 0 (1)
NOTICE: Measure of vertex 1 (0) not bigger than measure of vertex 0 (1)
NOTICE: Measure of vertex 2 (2) not bigger than measure of vertex 1 (3)
passed
The above is taken from this GitLab CI output:
https://gitlab.com/dbaston/postgis/-/jobs/56625842
The build environment is the following Docker image:
`dbaston/postgis-build-env:latest`
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4042>
