[postgis-tickets] [PostGIS] #4043: [liblwgeom] Memory leaks in trunk
PostGIS trac at osgeo.org
Fri Mar 9 09:43:13 PST 2018
  Reporter:  Raul Marin  |      Owner:  Algunenano
      Type:  defect      |     Status:  closed
  Priority:  high        |  Milestone:  PostGIS 2.5.0
 Component:  liblwgeom   |    Version:  trunk
Resolution:  fixed       |   Keywords:
Changes (by Raul Marin):
 * status:  assigned => closed
 * resolution:   => fixed
Comment:
 In [changeset:"16454" 16454]:
 #!CommitTicketReference repository="" revision="16454"
 Liblwgeom: Fix memory leaks
 Closes #4043
 Closes #https://github.com/postgis/postgis/pull/230
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4043#comment:1>
