[postgis-tickets] r16455 - Add ST_QuantizeCoordinates
Daniel Baston
dbaston at gmail.com
Sun Mar 11 07:41:56 PDT 2018
Author: dbaston
Date: 2018-03-11 19:41:56 -0700 (Sun, 11 Mar 2018)
New Revision: 16455
Added:
trunk/regress/quantize_coordinates.sql
trunk/regress/quantize_coordinates_expected
trunk/NEWS
trunk/doc/reference_misc.xml
trunk/liblwgeom/cunit/cu_algorithm.c
trunk/liblwgeom/liblwgeom.h.in
trunk/liblwgeom/lwgeom.c
trunk/postgis/lwgeom_functions_basic.c
trunk/postgis/postgis.sql.in
trunk/regress/Makefile.in
Closes #4029
Closes https://github.com/postgis/postgis/pull/225
Modified: trunk/NEWS
--- trunk/NEWS 2018-03-09 17:43:12 UTC (rev 16454)
+++ trunk/NEWS 2018-03-12 02:41:56 UTC (rev 16455)
@@ -9,6 +9,7 @@
- #3913, Upgrade when creating extension from unpackaged (Sandro Santilli)
- #2256, _postgis_index_extent() for extent from index (Paul Ramsey)
- #3176, Add ST_OrientedEnvelope (Dan Baston)
+ - #4029, Add ST_QuantizeCoordinates (Dan Baston)
* Breaking Changes *
- #3885, version number removed from address_standardize lib file
Modified: trunk/doc/reference_misc.xml
--- trunk/doc/reference_misc.xml 2018-03-09 17:43:12 UTC (rev 16454)
+++ trunk/doc/reference_misc.xml 2018-03-12 02:41:56 UTC (rev 16455)
@@ -695,5 +695,177 @@
</refsection>
</refentry>
+ <refentry id="ST_QuantizeCoordinates">
+ <refnamediv>
+ <refname>
+ ST_QuantizeCoordinates
+ </refname>
+ <refpurpose>
+ Sets least significant bits of coordinates to zero
+ </refpurpose>
+ </refnamediv>
+ <refsynopsisdiv>
+ <funcsynopsis>
+ <funcprototype>
+ <funcdef>
+ geometry
+ <function>ST_QuantizeCoordinates</function>
+ </funcdef>
+ <paramdef>
+ <type>geometry</type>
+ <parameter>g</parameter>
+ </paramdef>
+ <paramdef>
+ <type>int</type>
+ <parameter>prec_x</parameter>
+ </paramdef>
+ <paramdef>
+ <type>int</type>
+ <parameter>prec_y</parameter>
+ </paramdef>
+ <paramdef>
+ <type>int</type>
+ <parameter>prec_z</parameter>
+ </paramdef>
+ <paramdef>
+ <type>int</type>
+ <parameter>prec_m</parameter>
+ </paramdef>
+ </funcprototype>
+ </funcsynopsis>
+ </refsynopsisdiv>
+ <refsection>
+ <title>Description</title>
+ <para>
+ <code>ST_QuantizeCoordinates</code> determines the number of bits
+ (<code>N</code>) required to represent a coordinate value with a
+ specified number of digits after the decimal point, and then sets
+ all but the <code>N</code> most significant bits to zero. The
+ resulting coordinate value will still round to the original value,
+ but will have improved compressiblity. This can result in a
+ significant disk usage reduction provided that the geometry column
+ is using a <ulink
+ url="https://www.postgresql.org/docs/current/static/storage-toast.html#STORAGE-TOAST-ONDISK">
+ compressible storage type</ulink>. The function allows
+ specification of a different number of digits after the decimal
+ point in each dimension; unspecified dimensions are assumed to have
+ the precsion of the <code>x</code> dimension. Negative digits are
+ interpreted to refer digits to the left of the decimal point, (i.e.,
+ <code>prec_x=-2</code> will preserve coordinate values to the
+ nearest 100.
+ </para>
+ <para>
+ The coordinates produced by <code>ST_QuantizeCoordinates</code> are
+ independent of the geometry that contains those coordinates and the
+ relative position of those coordinates within the geometry. As a result,
+ existing topological relationships between geometries are unaffected
+ by use of this function. The function will not produce invalid geometry
+ unless it is called with a number of digits lower than the intrinsic
+ precision of the geometry.
+ </para>
+ <para>Availability: 2.5.0</para>
+ </refsection>
+ <refsection>
+ <title>Technical Background</title>
+ <para>
+ PostGIS stores all coordinate values as double-precision floating
+ point integers, which can reliably represent 15 significant digits.
+ However, PostGIS may be used to manage data that intrinsically has
+ fewer than 15 significant digits. An example is TIGER data, which is
+ provided as geographic coordinates with six digits of precision
+ after the decimal point (thus requiring only nine significant digits
+ of longitude and eight significant digits of latitude.)
+ </para>
+ <para>
+ When 15 significant digits are available, there are many possible
+ representations of a number with 9 significant digits. A double
+ precision floating point number uses 52 explicit bits to represent
+ the significand (mantissa) of the coordinate. Only 30 bits are needed
+ to represent a mantissa with 9 significant digits, leaving 22
+ insignificant bits; we can set their value to anything we like and
+ still end up with a number that rounds to our input value. For
+ example, the value 100.123456 can be represented by the floating
+ point numbers closest to 100.123456000000, 100.123456000001, and
+ 100.123456432199. All are equally valid, in that
+ <code>ST_AsText(geom, 6)</code> will return the same result with
+ any of these inputs. Because we can set these bits to whatever we
+ like, <code>ST_QuantizeCoordinates</code> sets the 22 insignificant
+ bits to zero because a block of 22 zeros is easily (and automatically)
+ compressed by PostgreSQL's built-in compression algorithm.
+ </para>
+ <note>
+ <para>
+ Only the on-disk size of the geometry is potentially affected by
+ <code>ST_QuantizeCoordinates</code>. <xref linkend="ST_MemSize"></xref>,
+ which reports the in-memory usage of the geometry, will return the
+ the same value regardless of the disk space used by a geometry.
+ </para>
+ </note>
+ </refsection>
+ <refsection>
+ <title>Examples</title>
+ <programlisting>SELECT ST_AsText(ST_QuantizeCoordinates('POINT (100.123456 0)'));
+st_astext
+POINT(100.123455941677 0)
+ </programlisting>
+ <programlisting>
+WITH test AS (SELECT 'POINT (123.456789123456 123.456789123456)'::geometry AS geom)
+SELECT
+ digits,
+ encode(ST_QuantizeCoordinates(geom, digits), 'hex'),
+ ST_AsText(ST_QuantizeCoordinates(geom, digits))
+FROM test, generate_series(15, -15, -1) AS digits;
+digits | encode | st_astext
+15 | 01010000005f9a72083cdd5e405f9a72083cdd5e40 | POINT(123.456789123456 123.456789123456)
+14 | 01010000005f9a72083cdd5e405f9a72083cdd5e40 | POINT(123.456789123456 123.456789123456)
+13 | 01010000005f9a72083cdd5e405f9a72083cdd5e40 | POINT(123.456789123456 123.456789123456)
+12 | 01010000005c9a72083cdd5e405c9a72083cdd5e40 | POINT(123.456789123456 123.456789123456)
+11 | 0101000000409a72083cdd5e40409a72083cdd5e40 | POINT(123.456789123456 123.456789123456)
+10 | 0101000000009a72083cdd5e40009a72083cdd5e40 | POINT(123.456789123455 123.456789123455)
+9 | 0101000000009072083cdd5e40009072083cdd5e40 | POINT(123.456789123418 123.456789123418)
+8 | 0101000000008072083cdd5e40008072083cdd5e40 | POINT(123.45678912336 123.45678912336)
+7 | 0101000000000070083cdd5e40000070083cdd5e40 | POINT(123.456789121032 123.456789121032)
+6 | 0101000000000040083cdd5e40000040083cdd5e40 | POINT(123.456789076328 123.456789076328)
+5 | 0101000000000000083cdd5e40000000083cdd5e40 | POINT(123.456789016724 123.456789016724)
+4 | 0101000000000000003cdd5e40000000003cdd5e40 | POINT(123.456787109375 123.456787109375)
+3 | 0101000000000000003cdd5e40000000003cdd5e40 | POINT(123.456787109375 123.456787109375)
+2 | 01010000000000000038dd5e400000000038dd5e40 | POINT(123.45654296875 123.45654296875)
+1 | 01010000000000000000dd5e400000000000dd5e40 | POINT(123.453125 123.453125)
+0 | 01010000000000000000dc5e400000000000dc5e40 | POINT(123.4375 123.4375)
+-1 | 01010000000000000000c05e400000000000c05e40 | POINT(123 123)
+-2 | 01010000000000000000005e400000000000005e40 | POINT(120 120)
+-3 | 010100000000000000000058400000000000005840 | POINT(96 96)
+-4 | 010100000000000000000058400000000000005840 | POINT(96 96)
+-5 | 010100000000000000000058400000000000005840 | POINT(96 96)
+-6 | 010100000000000000000058400000000000005840 | POINT(96 96)
+-7 | 010100000000000000000058400000000000005840 | POINT(96 96)
+-8 | 010100000000000000000058400000000000005840 | POINT(96 96)
+-9 | 010100000000000000000058400000000000005840 | POINT(96 96)
+-10 | 010100000000000000000058400000000000005840 | POINT(96 96)
+-11 | 010100000000000000000058400000000000005840 | POINT(96 96)
+-12 | 010100000000000000000058400000000000005840 | POINT(96 96)
+-13 | 010100000000000000000058400000000000005840 | POINT(96 96)
+-14 | 010100000000000000000058400000000000005840 | POINT(96 96)
+-15 | 010100000000000000000058400000000000005840 | POINT(96 96)
+</programlisting>
+ </refsection>
+ <refsection>
+ <title>See Also</title>
+ <para><xref linkend="ST_SnapToGrid" /></para>
+ </refsection>
+ </refentry>
</sect1>
Modified: trunk/liblwgeom/cunit/cu_algorithm.c
--- trunk/liblwgeom/cunit/cu_algorithm.c 2018-03-09 17:43:12 UTC (rev 16454)
+++ trunk/liblwgeom/cunit/cu_algorithm.c 2018-03-12 02:41:56 UTC (rev 16455)
@@ -1434,6 +1434,52 @@
return;
+static void test_trim_bits(void)
+ POINTARRAY *pta = ptarray_construct_empty(LW_TRUE, LW_TRUE, 2);
+ POINT4D pt;
+ LWLINE *line;
+ int precision;
+ uint32_t i;
+ pt.x = 1.2345678901234;
+ pt.y = 2.3456789012345;
+ pt.z = 3.4567890123456;
+ pt.m = 4.5678901234567;
+ ptarray_insert_point(pta, &pt, 0);
+ pt.x *= 3;
+ pt.y *= 3;
+ pt.y *= 3;
+ pt.z *= 3;
+ ptarray_insert_point(pta, &pt, 1);
+ line = lwline_construct(0, NULL, pta);
+ for (precision = -15; precision <= 15; precision++)
+ LWLINE *line2 = (LWLINE*) lwgeom_clone_deep((LWGEOM*) line);
+ lwgeom_trim_bits_in_place((LWGEOM*) line2, precision, precision, precision, precision);
+ for (i = 0; i < line->points->npoints; i++)
+ POINT4D pt1 = getPoint4d(line->points, i);
+ POINT4D pt2 = getPoint4d(line2->points, i);
+ CU_ASSERT_DOUBLE_EQUAL(pt1.x, pt2.x, pow(10, -1*precision));
+ CU_ASSERT_DOUBLE_EQUAL(pt1.y, pt2.y, pow(10, -1*precision));
+ CU_ASSERT_DOUBLE_EQUAL(pt1.z, pt2.z, pow(10, -1*precision));
+ CU_ASSERT_DOUBLE_EQUAL(pt1.m, pt2.m, pow(10, -1*precision));
+ lwline_free(line2);
+ lwline_free(line);
** Used by test harness to register the tests in this file.
@@ -1465,5 +1511,6 @@
PG_ADD_TEST(suite,test_median_handles_3d_correctly);
PG_ADD_TEST(suite,test_median_robustness);
PG_ADD_TEST(suite,test_lwpoly_construct_circle);
+ PG_ADD_TEST(suite,test_trim_bits);
PG_ADD_TEST(suite,test_lwgeom_remove_repeated_points);
Modified: trunk/liblwgeom/liblwgeom.h.in
--- trunk/liblwgeom/liblwgeom.h.in 2018-03-09 17:43:12 UTC (rev 16454)
+++ trunk/liblwgeom/liblwgeom.h.in 2018-03-12 02:41:56 UTC (rev 16455)
@@ -2170,6 +2170,20 @@
extern uint8_t* lwgeom_to_twkb_with_idlist(const LWGEOM *geom, int64_t *idlist, uint8_t variant, int8_t precision_xy, int8_t precision_z, int8_t precision_m, size_t *twkb_size);
+ * Trim the bits of an LWGEOM in place, to optimize it for compression.
+ * Sets all bits to zero that are not required to maintain a specified
+ * number of digits after the decimal point. Negative precision values
+ * indicate digits before the decimal point do not need to be preserved.
+ * @param geom input geometry
+ * @param prec_x precision (digits after decimal point) in x dimension
+ * @param prec_y precision (digits after decimal point) in y dimension
+ * @param prec_z precision (digits after decimal point) in z dimension
+ * @param prec_m precision (digits after decimal point) in m dimension
+extern void lwgeom_trim_bits_in_place(LWGEOM *geom, int32_t prec_x, int32_t prec_y, int32_t prec_z, int32_t prec_m);
* SQLMM internal functions
Modified: trunk/liblwgeom/lwgeom.c
--- trunk/liblwgeom/lwgeom.c 2018-03-09 17:43:12 UTC (rev 16454)
+++ trunk/liblwgeom/lwgeom.c 2018-03-12 02:41:56 UTC (rev 16455)
@@ -19,6 +19,7 @@
* Copyright (C) 2001-2006 Refractions Research Inc.
+ * Copyright (C) 2017-2018 Daniel Baston <dbaston at gmail.com>
@@ -2444,3 +2445,63 @@
return lwline_is_trajectory((LWLINE*)geom);
+static uint8_t
+bits_for_precision(int32_t significant_digits)
+ int32_t bits_needed = ceil(significant_digits / log10(2));
+ if (bits_needed > 52)
+ return 52;
+ else if (bits_needed < 1)
+ return 1;
+ return bits_needed;
+static inline
+double mask_double(double d, uint64_t mask)
+ uint64_t* double_bits = (uint64_t*) (&d);
+ (*double_bits) &= mask;
+ return *((double*) double_bits);
+static double trim_preserve_decimal_digits(double d, int32_t decimal_digits)
+ if (d==0)
+ return 0;
+ int digits_left_of_decimal = (int) (1 + log10(fabs(d)));
+ uint8_t bits_needed = bits_for_precision(decimal_digits + digits_left_of_decimal);
+ uint64_t mask = 0xffffffffffffffff << (52 - bits_needed);
+ return mask_double(d, mask);
+void lwgeom_trim_bits_in_place(LWGEOM* geom, int32_t prec_x, int32_t prec_y, int32_t prec_z, int32_t prec_m)
+ LWPOINTITERATOR* it = lwpointiterator_create_rw(geom);
+ POINT4D p;
+ while (lwpointiterator_has_next(it))
+ lwpointiterator_peek(it, &p);
+ p.x = trim_preserve_decimal_digits(p.x, prec_x);
+ p.y = trim_preserve_decimal_digits(p.y, prec_y);
+ if (lwgeom_has_z(geom))
+ p.z = trim_preserve_decimal_digits(p.z, prec_z);
+ if (lwgeom_has_m(geom))
+ p.m = trim_preserve_decimal_digits(p.m, prec_m);
+ lwpointiterator_modify_next(it, &p);
+ lwpointiterator_destroy(it);
Modified: trunk/postgis/lwgeom_functions_basic.c
--- trunk/postgis/lwgeom_functions_basic.c 2018-03-09 17:43:12 UTC (rev 16454)
+++ trunk/postgis/lwgeom_functions_basic.c 2018-03-12 02:41:56 UTC (rev 16455)
@@ -19,6 +19,7 @@
* Copyright 2001-2006 Refractions Research Inc.
+ * Copyright 2017-2018 Daniel Baston <dbaston at gmail.com>
@@ -58,6 +59,7 @@
Datum LWGEOM_length_linestring(PG_FUNCTION_ARGS);
Datum LWGEOM_perimeter2d_poly(PG_FUNCTION_ARGS);
Datum LWGEOM_perimeter_poly(PG_FUNCTION_ARGS);
+Datum postgis_optimize_geometry(PG_FUNCTION_ARGS);
Datum LWGEOM_maxdistance2d_linestring(PG_FUNCTION_ARGS);
Datum LWGEOM_mindistance2d(PG_FUNCTION_ARGS);
@@ -2983,3 +2985,41 @@
PG_RETURN_POINTER(ret);
+PG_FUNCTION_INFO_V1(ST_QuantizeCoordinates);
+Datum ST_QuantizeCoordinates(PG_FUNCTION_ARGS)
+ GSERIALIZED* input;
+ GSERIALIZED* result;
+ LWGEOM* g;
+ int32_t prec_x;
+ int32_t prec_y;
+ int32_t prec_z;
+ int32_t prec_m;
+ if (PG_ARGISNULL(0))
+ PG_RETURN_NULL();
+ if (PG_ARGISNULL(1))
+ lwpgerror("Must specify precision");
+ PG_RETURN_NULL();
+ else
+ prec_x = PG_GETARG_INT32(1);
+ prec_y = PG_ARGISNULL(2) ? prec_x : PG_GETARG_INT32(2);
+ prec_z = PG_ARGISNULL(3) ? prec_x : PG_GETARG_INT32(3);
+ prec_m = PG_ARGISNULL(4) ? prec_x : PG_GETARG_INT32(4);
+ input = PG_GETARG_GSERIALIZED_P_COPY(0);
+ g = lwgeom_from_gserialized(input);
+ lwgeom_trim_bits_in_place(g, prec_x, prec_y, prec_z, prec_m);
+ result = geometry_serialize(g);
+ lwgeom_free(g);
+ PG_FREE_IF_COPY(input, 0);
+ PG_RETURN_POINTER(result);
Modified: trunk/postgis/postgis.sql.in
--- trunk/postgis/postgis.sql.in 2018-03-09 17:43:12 UTC (rev 16454)
+++ trunk/postgis/postgis.sql.in 2018-03-12 02:41:56 UTC (rev 16455)
@@ -1099,6 +1099,13 @@
AS 'MODULE_PATHNAME', 'LWGEOM_hasBBOX'
LANGUAGE 'c' IMMUTABLE STRICT _PARALLEL;
+-- Availability: 2.5.0
+CREATE OR REPLACE FUNCTION ST_QuantizeCoordinates(g geometry, prec_x int, prec_y int DEFAULT NULL, prec_z int DEFAULT NULL, prec_m int DEFAULT NULL)
+ RETURNS geometry
+ AS 'MODULE_PATHNAME', 'ST_QuantizeCoordinates'
+ LANGUAGE 'c' IMMUTABLE _PARALLEL
+ COST 10;
-- DEBUG
Modified: trunk/regress/Makefile.in
--- trunk/regress/Makefile.in 2018-03-09 17:43:12 UTC (rev 16454)
+++ trunk/regress/Makefile.in 2018-03-12 02:41:56 UTC (rev 16455)
@@ -109,6 +109,7 @@
polygonize \
polyhedralsurface \
postgis_type_name \
+ quantize_coordinates \
regress \
regress_bdpoly \
regress_index \
Added: trunk/regress/quantize_coordinates.sql
--- trunk/regress/quantize_coordinates.sql (rev 0)
+++ trunk/regress/quantize_coordinates.sql 2018-03-12 02:41:56 UTC (rev 16455)
@@ -0,0 +1,14 @@
+-- Returns NULL for NULL geometry
+SELECT 't1', ST_QuantizeCoordinates(NULL::geometry, 6) IS NULL;
+-- Throws error if no precision specified
+SELECT 't2', ST_QuantizeCoordinates('POINT (3 7)', NULL);
+-- Preserves SRID
+SELECT 't3', ST_SRID(ST_QuantizeCoordinates('SRID=32611;POINT (3 7)', 5)) = 32611;
+-- Carries X precision through to other dimensions if not specified
+SELECT 't4', ST_X(ST_QuantizeCoordinates('POINT (1.2345678 1.2345678)', 3)) = ST_Y(ST_QuantizeCoordinates('POINT (1.2345678 1.2345678)', 3));
+-- Or they can be specified independently
+SELECT 't5', ST_X(ST_QuantizeCoordinates('POINT (1.2345678 1.2345678)', 7, 4)) != ST_Y(ST_QuantizeCoordinates('POINT (1.2345678 1.2345678)', 7, 4));
+-- Significant digits are preserved
+WITH input AS (SELECT ST_MakePoint(1.23456789012345, 0) AS geom)
+SELECT 't6', bool_and(abs(ST_X(geom)-ST_X(ST_QuantizeCoordinates(geom, i))) < pow(10, -i))
+FROM input, generate_series(1,15) AS i
Added: trunk/regress/quantize_coordinates_expected
--- trunk/regress/quantize_coordinates_expected (rev 0)
+++ trunk/regress/quantize_coordinates_expected 2018-03-12 02:41:56 UTC (rev 16455)
@@ -0,0 +1,6 @@
+t1|t
+ERROR: Must specify precision
+t3|t
+t4|t
+t5|t
+t6|t
